Browse Forums Home Theatre & Automation 1 Apr 21, 2009 8:16 pm I've been off this site for awhile due to work commitments. I've come back and there are the same questions being asked. Myself, Pugs and other members have answered alot of questions regarding data cabling and regulations and the same questions are being answered over and over again. I know it can be a hard area to understand and it may be easier for you to post a new topic based on your exact needs, but the information is already there. There are numerous threads on "starserve" cost, benefits, and usability as well as the cabling costs and ideas. Once you have read the information, then ask a specific question based on your requirements. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Please use the search engine. 2Apr 21, 2009 8:20 pm ++++ infinity...... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Please use the search engine. 4Apr 22, 2009 1:52 am Helyn should of used the search engine yourselves, hehehe, not that long ago there was a very long thread on exactly this topic lol touche ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: Please use the search engine. 5Apr 22, 2009 2:15 am Pugs and The Data Guy, this is a regular issue. You can check out how I and others handle it. There is an example here http://forum.homeone.com.au/viewtopic.php?f=9&t=17027&p=209497#p209497 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17888 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8316 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17543 |
