Browse Forums Home Theatre & Automation 1 Apr 21, 2009 5:05 pm Hi, I was after some advice on a media room in a plan that we are looking at. The room currently looks like this ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am wondering how suited this room is for a home theater style setup? I was thinking of having a setup with a projector that would project down the length of the room and I have been told by the designer/draftsman that the distance between windows 5 and 6 is only 2 meters. Thinking some more about this we would obviously need some pretty good block out blinds to control the light. My other concern is that would the 2 meter width restrict the screen size? (given the room dimensions). At the moment we are still in the plannng stage so there is the possibility to resize/remove the windows Assume for arguments sake, I was thinking along the lines of an Epson TW3000 projector and a fixed/wall mounted screen with a 5.1 setup (wired for 7.1 in the future) Any advice, thoughts comments are most definately appreciated! Cheers, Mark Re: Media Room Advice 2Apr 21, 2009 5:21 pm Hi Mark. Absolutely you need good blockout blinds or curtains (or both). As far as putting a screen at the window end of the room - you can either go with a roll-down screen (I always recommend motorised), or if you want to mount a fixed screen that's wider than the plaster wall between the windows you can always mount it out from the wall (with blocks or brackets) - Adrian Barber (one of our moderators) has done that, as has Matt in the Selby demo room... Re: Media Room Advice 3Apr 21, 2009 7:59 pm can you get rid of windows 5 and 6 and still comply with light and ventilation with the windows on the side? that would give you a bigger screen ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 3326 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 3000 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 11129 |
