Browse Forums Home Theatre & Automation Re: Postpone our home theatre plan 2Apr 16, 2009 10:24 pm Get the speaker cabling, the powerpoint for the projector and the HDMI run if you can. This may still come around $600-800 all up to have done. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Postpone our home theatre plan 3Apr 17, 2009 1:20 pm kikin Hi, We decide to postpone our plan on the home theatre due to out of budget If it is the case, is it possible for us to do the cabling and the power cord for projector later (after handover)? Thanks. If you have a single storey house with a tiled roof then you can pretty much do anything after you move in (it's just a bit more effort). If you want to be of some help without really outlaying any money for anything at this stage then consider either drilling some big (bigger than a 20c peice, perhaps) holes in noggins or if you can roll them onto their sides where every you may want to run any cabling... If you have a 2 storey house then things are not so easy... Re: Postpone our home theatre plan 4Apr 17, 2009 1:51 pm Wonder how much of a market could be created "Making cable friendly noggins" for builders to use in construction. They need not even be timber but some material that can still be nailed. Available per metre for site workers to cut and with 30mm dia holes every 200mm for example. kind of like this.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Postpone our home theatre plan 5Apr 17, 2009 2:02 pm not much even as a data cabler i don't see the point.... proberly the most fun i can have on a work site is drilling holes..... tho even with these you would need very smart sparkies to actaully stay in their own holes... I'm doing a 2 stroy house install atm and the sparkies could barely keep in a straight line with most of their cabling let alone leave me any where that i didn't have to aviod or put in conduits to aviod them Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Postpone our home theatre plan 6Apr 17, 2009 8:33 pm Rodda kikin Hi, We decide to postpone our plan on the home theatre due to out of budget If it is the case, is it possible for us to do the cabling and the power cord for projector later (after handover)? Thanks. If you have a single storey house with a tiled roof then you can pretty much do anything after you move in (it's just a bit more effort). If you want to be of some help without really outlaying any money for anything at this stage then consider either drilling some big (bigger than a 20c peice, perhaps) holes in noggins or if you can roll them onto their sides where every you may want to run any cabling... If you have a 2 storey house then things are not so easy... Thanks Rod! Perhaps I can do anything about home theatre afterwards as mine is single storey.... Thanks. Metricon Amira Re: Postpone our home theatre plan 7Apr 17, 2009 8:42 pm Rodda If you have a single storey house with a tiled roof then you can pretty much do anything after you move in (it's just a bit more effort). I'm just wondering why the tiled roof is easier than colorbond roof? Do you have more space in the ceiling or is there some other reason? Re: Postpone our home theatre plan 8Apr 17, 2009 9:45 pm It is easier as when you get to the outside walls (external) you can lift the tiles to make it easy to get cables down the wall. You cant lift a sheet of colorbond If all the cables are in internal walls then this is a little less of an issue. It is still possible but a lot more work and a bit more expensive as there is more time / energy /effort involved. Re: Postpone our home theatre plan 9Apr 17, 2009 9:59 pm mattwalker It is easier as when you get to the outside walls (external) you can lift the tiles to make it easy to get cables down the wall. ahhh yes that makes sense now... come to think about it,this is what the foxtel guy did when he installed the satellite at my rental here.... I'll be glad to get rid of satellite though and go back to cable in the new house... sick of not getting all the fta channels in the one box! i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17423 5 10556 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25267 |
