Browse Forums Home Theatre & Automation 1 Apr 08, 2009 10:35 am Following on from my question earlier....I was told by a bloke at D@ck Smiths that my laptop would not work with a wl N router as it only has wl G. I then read on the internet that it would work, but wouldnt improve the speed at all. Do you guys know anything about this? I know you can get an USB adaptor for the N router, but I am more interested in getting an N router for the gigabit ethernet ports. Cheers, Ryan Building Vancouver 33 - My Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=89689 Re: Wireless n and g question 2Apr 08, 2009 11:51 am it will work but there won't be any increase in speed and as "G" isn't a duplex standard you will have very slow speeds a second or 3 device is added. "N" is a duplex standard meaning as it sends it also receives and is a longer and stronger wireless signal (depending on your router/ if you have LoS to it and other things) maybe have a look over at OCAU or whingepool err i mean whirlpool and have a see what peopel recommend. http://forums.overclockers.com.au http://forums.whirlpool.net.au/ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wireless n and g question 3Apr 08, 2009 12:12 pm Thanks Pugs. Appreciate it! Building Vancouver 33 - My Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=89689 Re: Wireless n and g question 5Apr 09, 2009 10:17 am What's the model of your wireless N router? There's about a 99% chance that the router is compatible with G. It would make no sense for a manufacturer to try and phase out G, especially when N is still not mainstream. The bloke at DS was most likely trying to upsell you a wireless N adapter for your laptop ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5899 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6218 i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 4788 |
