No!
It requires a seperate amp to make noise...
Browse Forums Home Theatre & Automation Re: Speakers connection on Sonos System 24Apr 02, 2009 8:20 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Speakers connection on Sonos System 31Apr 06, 2009 10:02 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Speakers connection on Sonos System 34Apr 06, 2009 10:25 pm Kikin, Think of Cat6 as a higher performance version of cat5e. Many will state that its worth just installing cat5e as you can still reach gigabit data transfers across this cable. Cat6 is a higher bandwidth again. It runs at 200mhz vs 100 for the Cat5e. As for the install, laws these days as far as inwall installs goes need to be finished off by licenced cablers. How many data points were you thinking of? Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com 3 47414 Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need… 0 4260 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19497 |
