Browse Forums Home Theatre & Automation Re: Very simple cabling question. 2Mar 16, 2009 11:11 am Im sure someone will have some ****** around to test with but my guess would be 5 but they wouldnt be free to move in there, they'd bind on each other so dont plan on getting them out again. Obviously that's 5 without heads. Re: Very simple cabling question. 3Mar 16, 2009 11:22 am Five cables without heads sounds about right, but that means you would need to terminate the cables after they're passed through the conduit.
(If you draw it up, you can get nine 5 mm circules into a 20 mm circle with some room to spare. But check the inside diameter of the conduit, it may be well below 20 mm.) Trick question: How many assembled HDMI cables can you get dowen a 20 mm conduit. Answer: none (a HDMI cable head is 21 x 10.6 mm, so it won't fit). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Very simple cabling question. 4Mar 16, 2009 1:17 pm legally a data cabler can only install 2 in such a small conduit.... plus if you wish have installed RG6 aswell
you will need 25mm or 32mm conduits for more cables... (goes and gets his copy of AS/ACIF S009:2006 off the shelf...) 20mm up to 2 4pr cables (ie Cat5e or 6) 25mm up to 4 32mm up to 6 50mm up to 10 below is s guide on the % allowed to be filled inside a conduit with Cables one cable 53% two cables 31% three or more 40% Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 5Mar 16, 2009 1:57 pm Thanks Pugs
I was hoping to have two data points installed in each of 3 different rooms and have Cat 5e run to a switch in the study. Looks like that is not going to happen unless the builder is able to increase the size of the conduit. Have emailed them to see if I can have larger (32mm) conduit used, or should I just wear the extra cost and get 50mm installed for 'future needs'? Re: Very simple cabling question. 6Mar 16, 2009 2:04 pm 32 should be fine even for future needs as they would simply pull out the older cable anyways... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 7Mar 16, 2009 2:26 pm Sorry for going off topic, I've gotta ask, whats the requirement that prevents more than 2 Cat5 cables in a single 20mm conduit?
Pugs legally a data cabler can only install 2 in such a small conduit.... plus if you wish have installed RG6 aswell you will need 25mm or 32mm conduits for more cables... (goes and gets his copy of AS/ACIF S009:2006 off the shelf...) 20mm up to 2 4pr cables (ie Cat5e or 6) 25mm up to 4 32mm up to 6 50mm up to 10 below is s guide on the % allowed to be filled inside a conduit with Cables one cable 53% two cables 31% three or more 40% Re: Very simple cabling question. 8Mar 16, 2009 2:29 pm comes down to the ease of getting the cables pulled and being able to replace a single cable or both easier.....
any more questions call me Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 9Mar 16, 2009 3:12 pm Pugs comes down to the ease of getting the cables pulled and being able to replace a single cable or both easier..... any more questions call me So that makes it a legal requirement? wow, dont send the inspectors through any data centers! Thanks for the clarification. Re: Very simple cabling question. 10Mar 16, 2009 3:20 pm there are others but i CBF finding them call the acma if you really wan to find them out Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 11Mar 16, 2009 6:17 pm don't send the inspectors my way!
I have squeezed 6 in a 20mm. I had to go through a sandstone wall that was heritage listed so I couldn't increase the hole. Lotsa lube and teasing got em in there. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Very simple cabling question. 12Mar 16, 2009 7:01 pm The Data Guys don't send the inspectors my way! I have squeezed 6 in a 20mm. I had to go through a sandstone wall that was heritage listed so I couldn't increase the hole. Lotsa lube and teasing got em in there. Way to go. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Very simple cabling question. 13Mar 16, 2009 8:27 pm I did wonder how many. I could only get 25mm conduit put in. Lucky for most I only want 2 cables per conduit. Plenty of room. Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11769 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10021 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6181 |
