Pugs
you might need a third SD near th emaster bedroom...
We're having a sliding door in the WIR ..
Quote:
also why no internal doopr into the garage ???
There is but it's not showing in this floor plan.
Quote:
proberly the best location inthe garage is the wall backing onto the study..
Great, we'll have a think about it as well ..
Quote:
as for heat ..meh... only if yo cram it full of stuff you might have problems on rvery hot days or rans off hot days.... esp for the surface mount design ..if you had a the other you could atleast put some 12v or even two 80 -120mm 240v fans onthe thermal switch pushing some air around..
The garage will be facing the north and it's located on the eastern side of the house, so there shouldn't be that much heat in it. Choices
