Browse Forums Home Theatre & Automation 1 Mar 16, 2009 11:01 pm hi, i'm in the process of starting to build a new home, i am planning to try and do a discrete theater install into the living room area, i have been looking around at in wall mount speakers and have came to a stop at Niles, these speakers look to me like they are of very good quility (im no pro) i have decided to go with the HDLCRRP INWALL http://www.audioproducts.com.au/Product ... id=HDLCRRP for the front left/centre/right, and HDFXRP INWALL http://www.audioproducts.com.au/Product ... pid=HDFXRP for the rears, i have not yet decided on a sub.
Now to my questions, i would like to know if anybody has any opinions on these speaks/and choice of speakers. Also any recommendations for fitting/mounting (pros/cons for before and after plaster fitting). Regards Andrew. Re: Niles in wall speakers 2Mar 17, 2009 9:58 am Niles stuff is very good. It's actually at the more premium end of this type of gear, and therefore priced accordingly, on the same level as the Mordaunt-Short In-walls/In-ceilings (although I think the M-S are slightly cheaper for the same level of products ).
There are, obviously, brands out there that are more high-end and therefore also more expensive, and there are many brands out there that are in a more affordable area of price while still being good quality, genuine pedigree speaker brand made stuff (Paradigm, Jamo, to name a couple). What amp are you going to power them with? How big is the room? As for a subwoofer - don't kid yourself into thinking you can get an In-wall solution. In my experience you can't unless you go to great effort and cost. It is much simpler and cost effective, and you will get a much more predictable result, if you get a decent stand-alone sub an put it in a corner somewhere. There are many, many to choose from... Re: Niles in wall speakers 3Mar 17, 2009 5:47 pm Thanks for the reply Rodda,
I have not yet decided or even looked at an amp, my main focus so far is on the speakers/ cabling and placement. The room is 3.96x3.13 but is open to the meals area, it is also tiled, from what i have found out the niles are good for this kind of setup, from the data that i have read, they have adjustment on them to help "tune" for this kind of room. They also have very good info on placement as well. As for a Sub i have never thought of anything but a free standing, Regards Andrew Re: Niles in wall speakers 4Mar 17, 2009 6:25 pm andrew1977au ... from what i have found out the niles are good for this kind of setup, from the data that i have read, they have adjustment on them to help "tune" for this kind of room. They also have very good info on placement as well. Again, just to arm you with good info, most decent In-walls etc. have those adjustments (perhaps not in all of their entry level ranges, but certainly at the same level as the Niles stuff) - often referred to as boundary or room compensation adjustments (basically a treble and sometimes a bass adjustment, usually just a + or - 3dB switch). All decent ones also have good installation instructions... Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6748 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5565 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17864 |
