Browse Forums Home Theatre & Automation 1 Mar 12, 2009 2:53 pm We have decided that we will probably put a door on our Home Theatre room after hand over. Can anyone make a suggestion as to what door would be the best?
thanks www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Door for home theatre 2Mar 12, 2009 2:56 pm I used double sliding door as I didn't want to take up any floor space. Re: Door for home theatre 3Mar 12, 2009 3:55 pm We just have a standard single door.
The HT is in one corner, with across the entryway the garage, and through the other internal wall the kitchen, so noise travel wont be a problem Re: Door for home theatre 4Mar 12, 2009 3:58 pm We have double doors going into our HT. One opens again the external wall and the other opens against a void so they really don't stick out into the room, if that makes sense.....
Do you not want your builder to do it? Are they going to frame the opening for you? Happy at Home Re: Door for home theatre 6Mar 12, 2009 7:06 pm We are having on our HT room.
Provide 1No. set of double 2040mm high x 820mm wide and 2040mm high x 520mm wide hinged and latched Corinthian Atherton 4 panel doors in lieu of opening to Rumpus. The 820mm wide door is going to be located so that it opens up against the wall and the 520mm wide door opens up in the room so that it does not impact on the space inside the room so much. All up our opening will be 1.34m wide. Re: Door for home theatre 7Mar 12, 2009 8:23 pm Double internal cavity sliders are the way to go.. But thats no good after the fact... You can get doors made up to 1200mm wide... The standard largest size is 2040x920 or 2340x870... After that it is special order, and of course.... Kaching!! Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Door for home theatre 8Mar 12, 2009 10:54 pm We had no room for cavity doors (well only for one massive one, which would've looked ordinary) and we didn't want to take up space with normal doors. Seeing that the Lounge/HT is at the front of the home, we wanted something a nice to compliment the entry/gallery so we're having bi-folds (2 x 720mm) Re: Door for home theatre 9Mar 12, 2009 11:30 pm chuth77 Double internal cavity sliders are the way to go.. pick me ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Door for home theatre 10Mar 13, 2009 8:12 am I did exactly the same as WakeboardAndy in my last one (yet to get next house to begin next theatre), for the same reasons. thanks 12Mar 14, 2009 5:26 pm Thanks everyone for your input
We have asked our builder and we are now looking for a door(s). It's quite a wide doorway so it does present a problem in itself. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Door for home theatre 13Mar 14, 2009 6:09 pm chuth77 Double internal cavity sliders are the way to go.. But thats no good after the fact... You can get doors made up to 1200mm wide... The standard largest size is 2040x920 or 2340x870... After that it is special order, and of course.... Kaching!! What's the maximum width of a cavity door ? 1200mm ? 920mm sounds good because I'm concerned about the fat wide HT couches Re: Door for home theatre 14Mar 14, 2009 6:54 pm ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Door for home theatre 16Mar 14, 2009 7:50 pm I was charged $1020 for double cavity 820mm sliding doors
Ah well at least it'll look more suitable for a HT room! Our Blog! http://cityplantation.blogspot.com | Building the Havana 485 with Plantation Homes (Henley) Re: Door for home theatre 17Mar 14, 2009 8:24 pm iTalk What's the maximum width of a cavity door ? 1200mm ? 920mm sounds good because I'm concerned about the fat wide HT couches You can get 1200 doors made up as specials... Anything above 920mm in a 2140 tall door is custom made... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Door for home theatre 18Mar 15, 2009 11:39 pm If your going to all that trouble get a dedicated sound proof door.
or at least use solid timber not a crappy 4 panel etc. Re: Door for home theatre 19Mar 16, 2009 7:14 am kassan1973 If your going to all that trouble get a dedicated sound proof door. or at least use solid timber not a crappy 4 panel etc. Can volume builders provide such a thing ? Do you have a company that can provide these doors ? Can this be done after handover ? Re: Door for home theatre 20Mar 16, 2009 2:14 pm Do a search on google or give audio trends in Ringwood a call.
Good range from $1200 - $3000. if you want to spend that much 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1199 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16289 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6355 |
