Browse Forums Home Theatre & Automation Re: Theatre room 5.81 x 4.43 21Mar 05, 2009 9:44 am ^^ Stuff like Viera Link (panasonic tech) always 'seems' great, but Ive never seen anyone actually use it.
I Would like that, but seriously probably never will Re: Theatre room 5.81 x 4.43 22Mar 05, 2009 12:03 pm Rodda Basically, unless you have a really, really good reason for grouping your brands, just pick the best piece of equipment based on it's merrits... Or if you have a brother that works for a company that makes amps and speakers and you can get them at redicoulus prices, that is also a very good reason! Re: Theatre room 5.81 x 4.43 23Mar 05, 2009 12:08 pm wakeboardandy Or if you have a brother that works for a company that makes amps and speakers and you can get them at redicoulus prices, that is also a very good reason! ah the truely best way to get equipment... other then being in the industry itself.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Theatre room 5.81 x 4.43 24Mar 05, 2009 5:14 pm Thanks for the clarification Hellman109 , but what I was getting at was that I was going to make it more of a rumpus type of room with a pool table, bar no TV etc..
Thanks ever so much for all the advice Basically what I am looking to get (please excuse me if I miss some crucial part of the system ) is the screen, the projector, some piece of equipment I think a reciever?? and speakers to be only in that room though, something simple that I am able to use. Another couple of questions, I cannot believe how silly I am going to sound, but can you watch normal TV via a projector? Also, to watch a DVD, where does the DVD player sit?? Technology is definately not my thing... Cheers Re: Theatre room 5.81 x 4.43 25Mar 05, 2009 10:02 pm OK, so you're just talking about picture and sound in the one room - the room that will be (possibly among other things) the cinema.
For the picture you need a projector (you said you wanted to go this way) and you should use a proper screen with it. For the sound you need something to decode the surround sound signals from your DVDs etc. and something to power your speakers (that's what an amplifier does). This is where the AV Receiver comes in - it does all of this and a fair bit more. It can, and usually does, act as the central hub in your audio and video system (don't bring up PCs guys, Tillie will not be interested in complicating matters with one of those...). You then need gear like a DVD or perhaps Blu-Ray player (for obvious reasons), a Set-Top-Box or perhaps PVR (recorder) for watching TV (digital) signals, and any other type of device that is used for delivering pictures, sound or both. -- So yes, you can watch TV on a projector (HDTV looks magnificent on HD projectors...). The equipment can sit ANYWHERE in the house. It's simply a matter of cabling. If you want to be able to control the gear from a room or anywhere where you can't actually see it (and therefore the IR remote(s) won't be able to see the gear to control it either) then you simply need to install an IR repeating kit - and cable it also - which is not difficult or expensive. Re: Theatre room 5.81 x 4.43 26Mar 06, 2009 8:23 am Thanks very much Rodda for your clear and simple explaination I was dreading looking at the topic this morning as I was quite embarrassed asking a few of those questions
As you have stated that the equipment can be anywhere in the house, I would imagine that the closer it was the easier with the wiring etc?? as this shall be done once I am in the house. With what you have suggested in regrads to equipment/installation, for what I am after does the $5-7k still sound like a reasonable budget? Cheers Re: Theatre room 5.81 x 4.43 27Mar 06, 2009 9:27 am Hi again Til.
The biggest difference the location of the gear can make is if the gear is in the theatre itself and is in view then you won't need an IR repeating kit. Other than that, the only other difference is the further away from the theatre the gear is the slightly more expensive the cabling gets (as there is more...). As far as budget goes, $5K-$7K is on the money if you're going for lower-end gear (still good brands, just their 'entry-level' stuff...), especially if you don't want a HD projector. A HD projector will add more than $1500 to the budget (hence my earlier suggested budget of $7K-$8K if you included a HD projector - which I still highly recommend if you're going to go to the trouble of doing everything else)... Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4714 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13729 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9192 |
