Browse Forums Home Theatre & Automation 1 Mar 03, 2009 3:28 pm I have a Denon HT amp that does not have support HDMI. In order to achieve best pic and sound what is the best way to connect blu ray to amp and projector? Can i connect projector direct to blu ray with hdmi and use optical audio from blu ray to amp??
cheers Re: Connecting blu ray to non hdmi amp 2Mar 03, 2009 3:30 pm yes... as lomg as it has all the right connectors or your able to do this with adaptors.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Connecting blu ray to non hdmi amp 3Mar 03, 2009 3:39 pm Ideally yes, HDMI to the Projector and Optical to the Amp.
IIRC Optical cant do the 'lossless' codecs on newer Bluray stuff, but chances are neither can your amp, so nothing lost there. Otherwise DVI will give the same quality image if thats a choice. Re: Connecting blu ray to non hdmi amp 4Mar 03, 2009 3:47 pm You can connect this way, but you will not get any of the new HD audio formats (Dolby Digital Plus, Dolby TrueHD, DTS HD Master Audio) without the audio being sent via HDMI to the amp/AV Receiver, unless the Blu-Ray player has 5.1/7.1 analogue outputs (not as common as you'd think it should be) and can decode HD audio internally and send it via the analogue outs (your amp/AV Receiver would also have to have 5.1/7.1 inputs).
You will get regular Dolby Digital and DTS digital audio signals though. Re: Connecting blu ray to non hdmi amp 5Mar 03, 2009 3:56 pm thanks..looks like i need to start saving for an upgrade.. this set up wont give me on screen display from amp for set up and tweeking, is it possible to run a second component or composite from Blu ray -amp-projector?/
cheers again Re: Connecting blu ray to non hdmi amp 6Mar 03, 2009 3:58 pm You may also have an issue with Audio and Video sync (unless you have Time Base Correction ...TBC) too...
A new amp will fix all your problems Re: Connecting blu ray to non hdmi amp 7Mar 03, 2009 4:07 pm mattwalker You may also have an issue with Audio and Video sync (unless you have Time Base Correction ...TBC) too... A new amp will fix all your problems ... including a 2nd video output... Re: Connecting blu ray to non hdmi amp 8Mar 03, 2009 4:07 pm Matt you are killing me...TBC?? more research, about to build a new house so the upgraded amp wont be an option for quite a while..what is TBC ? Is it add on equipment or something my amp has??..failing this might just be an old fashioned component install. Re: Connecting blu ray to non hdmi amp 9Mar 03, 2009 5:53 pm TBC = Time Base Correction
Allows you to bring the video and Audio into sync if they are out. Re: Connecting blu ray to non hdmi amp 10Mar 03, 2009 6:00 pm TBC, also known as things like 'audio sync' is included in most mid and higher level AV recievers. Eg. Everything from Marantz's SR-5003 and up has it included... Building Standards; Getting It Right! G’day everyone, I am reaching out to share my pre-lining building inspection report, hoping to gain insights from those who may have encountered similar instances of… 0 678 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 37 23738 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5465 |
