Browse Forums Home Theatre & Automation Re: Television distribution/amplifier options 12Jun 02, 2009 7:53 am wakeboardandy Telstra owns the Foxtel cable network. So it will have to connect to Telstra's network for you to be able to get Foxtel. Yes, Telstra own the HFC cable network. However, this is Foxtel/Austar/SelecTV over pure optic fibre, which is owned and operated by Opticomm. I assume there is a connection to the TV networks somewhere (likewise, they redistribute the digital and analog FTA signals), but from a consumer point-of-view, I'm not connected to Telstra at all. But yes, my original point was a little broad -- there's a connection to Telstra somewhere, I just don't see it. Re: Television distribution/amplifier options 13Aug 06, 2021 6:11 pm From my experience, it's worth taking a look at https://www.myamplifiers.com/en-ca/ The booster I've bought still works properly Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12002 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6454 |
