Browse Forums Home Theatre & Automation 1 Feb 14, 2009 3:41 pm hey looking for a multi room audio device that fits in a standard wall palte space has an inbuilt amp and yu can plug in say an Ipod locally....
the tafe trainer i had had these and i've left a few messages for him yet he hasn't replied ... anyone seen and or use and know wher ei can get soem from for a client ??? Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: multi room audio 2Feb 15, 2009 3:17 pm Pugs, are you sure there wasn't more to it than simply one device not much bigger than a cigarette packet? Where are the speakers? How is it powered? How is it controlled?
My guess is that it was part of a system rather than being the whole system itself, like this: http://www.jamo.com/Default.aspx?ID=141 ... ctID=17788 Re: multi room audio 3Feb 15, 2009 5:49 pm part of a larger system.. powered from a 12V psu back in a "comms" rack <not an issue for the client was like a clipsal/hills tv cbus cabinet
had a "source selector", volume control and 3.5mm input on it. was about the size of a cigi pack at the back. speakers where run from it to anywhere in the room, and had "main" source feed in the comms rack... had a european sounding name Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: multi room audio 4Feb 16, 2009 7:42 am Jamo is European.
There are many multi-room audio systems available, and a few do things a little differently (like your example where the amplifier is in the wallplate - like the Jamo system, a setup that I personally believe is not the best way to do it... I prefer the more standard way where your electronics - including the amplifier(s), are all centrally located and only the controls (keypad) and speakers are in the rooms - like the Elan System 6. Management of the system is more simplified this way. Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9187 |
