Browse Forums Home Theatre & Automation 1 Feb 13, 2009 5:43 am I am meeting up with the electrician and going to ask him to wire a pp and tv point out in Alfresco.
I am hoping to be able to get a cheap lcd to mount on the wall next summer if funds allow. ( Ive seen them for around $400). That way dh will sit outside with me instead of watching the cricket inside Dont want nothing too flash only enough to see whats going on and listen to the score so sound and picture quality hasnt got to be the bees knees if it has dvd in it even better then i can watch music ones Anyone got any experiences with this, like is it safe electically wise or will moisture in the air cause problems. would it be too bright to see the tv properly, it is north east facing but the tv will be on the house wall 3.5 meters away from the edge of the alfresco roof. or does anyone know of any pros and cons regarding this? Thanks. Know where your going in life............... you may already be there Re: LCD TV under Alfresco 2Feb 13, 2009 6:50 am Biggest problem will be condensation inside the unit... like when your car is covered in moisture some mornings...
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: LCD TV under Alfresco 3Feb 13, 2009 8:03 am You can get commercial plasmas and LCDs that have higher tollerances for heat and moisture. They do cost a little more though... Re: LCD TV under Alfresco 4Feb 13, 2009 11:49 pm We were planning to do the same thing!.
We are definitely getting a tv point to the alfresco too but weren't too sure whether to put a tv out there permanently or not. Would look awesome but for us, would probably not be utilised all that frequently. After reading about the condensation issue, the decision is a no-brainer.... the TV will stay inside until needed. Re: LCD TV under Alfresco 5Feb 13, 2009 11:51 pm all you need outside anyways is an IP66 rated power point/ box and TV socket then you would be set... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: LCD TV under Alfresco 6Feb 14, 2009 7:08 am Spoke to the electrician and he said its no problem he does them quite a bit .
Just make sure I get a secure bracket so noone will bump my tv off. So maybe I can just hook it up for summer or weekends when I'm going to be out there, as it will only be a portable tv size so shouldnt be too heavy. I notice when I play golf theres a guy there that has one and it seems to be a permenant fixture. I wonder if you can get special covers for them for when they are not in use! Know where your going in life............... you may already be there Re: LCD TV under Alfresco 7Feb 14, 2009 8:27 am Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4198 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4891 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1675 |
