Browse Forums Home Theatre & Automation 1 Feb 05, 2009 8:38 pm Re: Subwoofer - Good, bad or just alright ? 2Feb 06, 2009 8:45 am The fact that (on paper) it has a 10" driver and claims it can get down to 25Hz makes it a pretty good buy at that price. I would have thought it's amp could have more power than 100W though, which in my opinion is a bit weak at this price point...
There is this one as an alternative, and can be found for the same price as the Yammy: http://www.qualifi.com.au/index.jsp?ref ... duct=24239 I think it's quite important for your subwoofer to have a bit of power, so it can maintain control when being asked to go hard (you start pushing subs with lower powered amps and like other audio applications they start to distort, which in subs = farting and adding other artifacts to what should just be clean, deep bass thump) You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 12905 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 25264 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - Iām new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 14126 |
