Mr Overwhelmed would like to know if anyone has IP Network cameras installed in their house, what products they used/ can recommend.
Thank you
Browse Forums Home Theatre & Automation 1 Jan 11, 2009 10:27 am Mr Overwhelmed would like to know if anyone has IP Network cameras installed in their house, what products they used/ can recommend.
Thank you Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: IP Network Camera 2Jan 11, 2009 8:52 pm I have a bit of experience with IP cams and for a permanent setup they are not IMO ideal.
If you are going with a more permanent setup go with a seperate DVR and cams. If it is just for occasionally go with the IP cam. Re: IP Network Camera 3Jan 12, 2009 9:11 am agree with Matt
they are also significant more expensive than traditional cameras. Also if you do a cost/quality ratio you can get the same quality as IP cameras for a whole lot less. ---->Some say that a recession is when your neighbour loses his/her job while a depression is when you lose yours!<----- Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5880 which 1) PoE based video intercom is best for two storey home. I am looking with two monitor, one in GF and another FF so someone in home can… 0 24958 |
