Browse Forums Home Theatre & Automation 1 Jan 04, 2009 12:10 am Hi,
With my budget of $2000 for home theatre, I did some research and found some products for our home theatre room. Projector - Epson EB-W6 - $1350 1280x800 WXGA, 2000:1 Contrast Ratio, 1590 Lumens Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sound system - Yamaha YHT-195 - $600 5 channel 500W powerful surround sound (100W x 5) 1080p-compatible HDMI switching (2 in/1 out) including 1080p/24Hz repeat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Are they suitable for entry level user? Any comments are welcome Thank you. Metricon Amira Re: $2000 budget of my home theatre choice 2Jan 04, 2009 12:23 am The Yamaha set is great value!
I have one in my office If you know where to llok they can be had for as little as $469 As for the projector there may be a bit better value out there also... Re: $2000 budget of my home theatre choice 3Jan 04, 2009 12:30 am mattwalker The Yamaha set is great value! I have one in my office If you know where to llok they can be had for as little as $469 As for the projector there may be a bit better value out there also... Thanks, Matt Do you have any alternative models of projectors and sound systems with similiar prices that you may suggest? Metricon Amira Re: $2000 budget of my home theatre choice 4Jan 04, 2009 12:41 am if you don't have 5.1 sound now... you will be amazed at the difference even from a basic set like that...
Projector wise I am probably going with the new sanyo z3000 but it is about the 3.5k mark.. so not sure what the lower res ones are like pricewise. Also have you budgeted for a screen? or are you just going to have it projected on the wall? Re: $2000 budget of my home theatre choice 5Jan 04, 2009 10:57 am wakeboardandy if you don't have 5.1 sound now... you will be amazed at the difference even from a basic set like that... Projector wise I am probably going with the new sanyo z3000 but it is about the 3.5k mark.. so not sure what the lower res ones are like pricewise. Also have you budgeted for a screen? or are you just going to have it projected on the wall? Great, Matt!! Thanks for your suggestion For the screen, I found it is not too expensive even the motorised one which costs about $400 on ebay I probably go with the motorised one Metricon Amira Re: $2000 budget of my home theatre choice 6Jan 27, 2009 5:22 am Just wondering whats this 2 in 1 out thing you mentioned on the yamaha set up?
I am buying a panasonic plasma and was going to connect it too my old panasonic 5.1 system. Dont think this has HDMI things in it though. Am I better to buy a system with these slots in to go with a plasma or stick to my old one? All this technology is new too me and I'm still trying to come to grips with what it all means Know where your going in life............... you may already be there Re: $2000 budget of my home theatre choice 7Jan 27, 2009 10:14 pm Taffy Just wondering whats this 2 in 1 out thing you mentioned on the yamaha set up? To answer your question, "This receiver features dual HDMI inputs and one output that can handle HD format including 720p, 1080i and 1080p so users can connect two HDMI sources, such as a DVD player and a HD set top box and enjoy the highest possible quality with HD display". In short, it also handled HDMI video from 2 sources to output to 1 source. Source: http://www.yamahamusic.com.au/products/ ... 95_NPB.pdf Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3484 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16289 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110592 |
