Browse Forums Home Theatre & Automation Re: Thinking of Not pre-wiring 4Jan 02, 2009 11:28 pm Adrian B I cannot find the photos but I negotiated with my site super to drill holes in noggins and run rope thru the so I could pull cabling through later. Would love to see the pictures Adrian. When you say noggins, isn't that part of the frame near the joints? So you drilled holes in the frame and ran rope through a hole in the plaster wall as well? isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13759 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8713 |
