Browse Forums Home Theatre & Automation 1 Dec 19, 2008 8:01 pm I'm looking at getting a projector Two projectors i've been interested in are the Sony HW10 and the Panasonic PTAE3000. Both have had good reviews, are there any other projectors I should be looking at?
Any advice would be helpful. Thanks. Metricon Amira Re: Sony HW10 or Panasonic PTAE3000, which is better? 2Dec 20, 2008 7:00 am What about DLP projectors? There are many of us that have definite preference for DLP over LCD... Re: Sony HW10 or Panasonic PTAE3000, which is better? 3Dec 20, 2008 8:53 am Thanks for your suggestion, Rod.
As I'm not expert on AV stuffs, may I ask the difference among DLP, LCD and SXRD? I just heard from a salesperson about SXRD. It is a technology by Sony, is Sony good on projectors? Any recommendations? May I also ask what the pro and con for DLP, LCD and SXRD are? Metricon Amira Re: Sony HW10 or Panasonic PTAE3000, which is better? 4Dec 20, 2008 9:46 am it is like plasma vs lcd... go and see for yourself and then choose which one you like best... some people can get sick from watching single dlp's projectors so defintely make sure you are ok with it before buying one. brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7575 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 843 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 |
