Browse Forums Home Theatre & Automation 1 Dec 13, 2008 2:31 pm Hello All
Lets say I hooked up a playstation 3 with rca component cables to a non high def sharp projector. What I would like to know is if I played a blueray through the above connection, would the picture be better than the equivalent connections from a normal dvd? I realise that it would not be Full HD, but would it be better, maybe even high def? Just wanted to know before I unhook things and test. (come to think of it does playstation 3 even have rca compoinent output?) Re: Blueray to non high def display 2Dec 13, 2008 3:18 pm PAL DVD = 576P
NTSC DVD = 480P What resolution is the projector? Can the projector receive a 720P or 1080i/P signal via it's Component Video inputs? Re: Blueray to non high def display 3Dec 13, 2008 8:26 pm Thanks for that Rodda.
I have done a little more research since posting, and the projector does 800*600 (DLP). Pretty poor from what i understand. So from what i understand wont get better than the values that you quoted in your reply. Thanks for your time From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5480 Thanks. There are plenty of builders around my suburb. I'll make sure to do some door-to-door knocking, or note their building details on the temp fence. 4 4752 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10217 |
