Hi,
I have just placed my LCD on my wall and I need to set up my PS3 and set top box and was wondering if these are any good to use for this as I want to hide the cables.
http://www.cablechick.com.au/cables/3-r ... plate.html
Browse Forums Home Theatre & Automation 1 Oct 08, 2008 1:36 pm Hi,
I have just placed my LCD on my wall and I need to set up my PS3 and set top box and was wondering if these are any good to use for this as I want to hide the cables. http://www.cablechick.com.au/cables/3-r ... plate.html If at first you don't succeed, try, try again. Then quit. There's no use being a damn fool about it. W.C. Fields Brought Established. Re: Are these good to use. 2Oct 08, 2008 2:42 pm They are fine.
That said, if your going to have a PS3 in the loop, you should consider including HDMI in your plans.... Try one of these: http://www.selbyacoustics.com.au/storef ... =235954803 Re: Are these good to use. 3Oct 08, 2008 4:25 pm Wingies Hi, I have just placed my LCD on my wall and I need to set up my PS3 and set top box If you have cabinet on the floor I would just install blank wall plate and holesaw cantre, get a bit longer cables and run cables from units through this blank wall plate directly to the TV inside the wall. Any joiners (=wall plates) degrade signal quality and some of these wall plated are expensive enough. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: Are these good to use. 4Nov 16, 2008 2:03 pm IQtech Wingies Hi, I have just placed my LCD on my wall and I need to set up my PS3 and set top box If you have cabinet on the floor I would just install blank wall plate and holesaw cantre, get a bit longer cables and run cables from units through this blank wall plate directly to the TV inside the wall. Any joiners (=wall plates) degrade signal quality and some of these wall plated are expensive enough. Yeah I was thinking the same wall plates probably aren't the best thing to connect HDMI cables....could degrade the quality like you said. Instead run the cables inside the wall to the cabinets...Im not sure why Im repeating things you said. Sorry Re: Are these good to use. 5Nov 17, 2008 8:33 am Sacha1390 IQtech Wingies Hi, I have just placed my LCD on my wall and I need to set up my PS3 and set top box If you have cabinet on the floor I would just install blank wall plate and holesaw cantre, get a bit longer cables and run cables from units through this blank wall plate directly to the TV inside the wall. Any joiners (=wall plates) degrade signal quality and some of these wall plated are expensive enough. Yeah I was thinking the same wall plates probably aren't the best thing to connect HDMI cables....could degrade the quality like you said. Instead run the cables inside the wall to the cabinets...Im not sure why Im repeating things you said. Sorry isn't HDMI a digital signal? so how would it get affected? Re: Are these good to use. 6Nov 17, 2008 9:25 am HDMI loses signal strength, and perhaps quality, over cable distance (have a look at Monster Cable's web site - even they say they can guarantee full 1080P over lengths of up to 7m via their HDMI cables. What happens after that).
And, the more breaks/joins in the cable run the more you add to this issue... Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19158 |
