Browse Forums Home Theatre & Automation Re: TV mounted above gas fireplace yay or nay? 11Jul 07, 2018 12:03 am TVs will survive above the fireplace. However Tv's should be mounted at eye level when you're sitting down rather than you looking up. If the height doesn't bother you, go for it. Re: TV mounted above gas fireplace yay or nay? 12Oct 15, 2018 11:21 pm Generally not an issue with heat, the brick wall won't conduct the heat and as most heat is radiated, the TV again will not receive this heat directly. So long as all wiring and cabling rules are followed in terms of cabling to that TV, it can be done safely. In terms of looks, some people find the fireplace is distracting as nearby. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: TV mounted above gas fireplace yay or nay? 13Jul 03, 2019 10:22 am there's nothing wrong with doing it with todays modern gas heaters, however the main consideration is TV height. Optimal TV height is where your eye level while sitting down is exactly 1/3rd of the way up the TV height. For a 75inch TV this means the bottom of the TV needs to be about 80cm off the ground. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72342 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13729 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11589 |
