Browse Forums Building A New House 1 Aug 13, 2020 6:20 pm Hi all, we are doing a KDR, building a Metricon Duxton Isla 35, demolition starts next week Electricity and gas have been abolished and now need to sort out an underground pit. As far as I know, I need to submit an application to United Energy and provide them with a site sketch? Anyone know the process? The form also asks for my registered electrical contractor. Any help will greatly be appreciated, cheers. Re: Underground Power Pit Process? 2Sep 15, 2020 2:32 pm It is pretty straight forward, mine cost about $5k at start of the year with United Energy in south east Melbourne. All I did was complete the form as well as the sketch. They then send someone out to validate accuracy and provide you a quote which I think lasts 3 months. In terms of electrical contractor, I don't think I had to provide any detail as it was part of a KDR and therefore the electricity was not being turned on straight after. The only other point i'd highlight is that you may want to ask for 3 phase instead of single. From memory there was no additional cost for this. Re: Underground Power Pit Process? 5Feb 24, 2021 9:03 pm I got a quote for 3phase 76Amp as below. The pit is just 2 meters from the pole. Is this sound reasonable? Cost of Pit Installation $ 4900.00 Additional Cabling Cost (2) meters $ 143 Total Cost Payable (including GST) $ 5043.00 Re: Underground Power Pit Process? 9Oct 19, 2022 7:46 am Kotex yeh, That's big increase. I was told normally cabling including to some length. Any idea to get this reviewed with someone from supplier ? Hi Kotex did you have any luck getting this reviewed? Did they give you breakdown or just 1 figure? I've been quoted just under $5.5 with the existing pole 1-2m from the pit - have tried to call and email but can't get any response from supplier. Re: Underground Power Pit Process? 10Oct 22, 2022 7:50 am Serog Kotex yeh, That's big increase. I was told normally cabling including to some length. Any idea to get this reviewed with someone from supplier ? Hi Kotex did you have any luck getting this reviewed? Did they give you breakdown or just 1 figure? I've been quoted just under $5.5 with the existing pole 1-2m from the pit - have tried to call and email but can't get any response from supplier. Hi Serog, I am going to have to go through the same process. May I know where you are building and who is your electricity distributor. I am planning KDRB in Vermont South and have to go through United Energy. I have to fill out the form in their online portal. If you are with United Energy, can you please contact me on 0402667667. Need to clarify a few things. Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3939 1 4082 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9531 |
