More than likely not, if you have the money why would you compromise? You get what you pay for. If you get a cheaper price there is a reason for it being cheaper
Browse Forums Building A New House Re: Million dollar home in Perth 26Sep 03, 2020 12:23 pm Hi Shai, Just thought we would drop a line to give you a first look at how you can walk-through your home before its built. We are a specialised team based in Sydney that provide full VR walk-through's for off the plan homes. We've helped hundreds of people in your position make sure their home project is exactly as expected and saved our customers thousands in design changes and variations along the way. If you have any questions or want to know more drop us a line or check out. Regards Antonio G. e. antonio@4dco.com.au Re: Million dollar home in Perth 27Sep 03, 2020 8:45 pm ![]() For that sort of money is be aiming higher than 7 star. 6 stars in the minimum of Australia very poor standards. Plus houses rarely actually achieve the rating they are designed to, with poor insulating installation etc. Up the rating to 8 star, trimming the house size to pay for it. Ongoing heating/cooling & maintenance costs will be lower. A smaller home will be easier to keep clean. The embodied energy (emissions created to build the home) will be lower for a smaller home. Your wallet, the environment & your children will thank you. Architect designed home to maximise natural heating and cooling. Insulated outer walls and roof space, Grey water storage , Solar panels, Glazed windows and Eaves designed to minimise heat creep where needed. Really that is all one can do then pay 5000 to get it professionally certified and hope for the best possible rating unless someone is willing to look into alternative material like rammed earth or insulated boards instead of double brick. With the rating, the designer or the builder cannot guarantee a certain rating , as long as minimum requirements are met it is deemed to be a 6 star rated house which may not always be true. Re: Million dollar home in Perth 28Sep 03, 2020 8:53 pm Well, my latest BASIX came up as 9.4 stars, however, they were not able to find right windows so they used one with U value of 1.2, while the actual windows I am planning putting it have U value of below 0.7. And if I left it the way my architect initially designed it, it would quite be hard to push it above 7 stars. Not a lot of architects are capable of designing efficient homes those days, unfortunately. I think what is important is to make sure the house is built to BASIX, this is why I am planning to use infrared camera as well as blower door testing. Re: Million dollar home in Perth 29Sep 03, 2020 8:59 pm ![]() Hi Shai, Just thought we would drop a line to give you a first look at how you can walk-through your home before its built. We are a specialised team based in Sydney that provide full VR walk-through's for off the plan homes. We've helped hundreds of people in your position make sure their home project is exactly as expected and saved our customers thousands in design changes and variations along the way. If you have any questions or want to know more drop us a line or check out. Regards Antonio G. e. antonio@4dco.com.au Thanks Antonio most of the builders are providing a CAD walk through and to be honest, taking pictures of an existing house and stitching them would give an accurate 3d walk through but what you are proposing is a close to the real deal which I am guessing is based on the material spec sheet provided to you and pictures from suppliers website. of said materials. Undoubtedly it will help people visualise instead of looking at a small floor tile or paint swab but at this juncture I am not sure I will be needing your services however I will ping you if I change my mind. Re: Million dollar home in Perth 30Sep 03, 2020 9:01 pm ![]() Well, my latest BASIX came up as 9.4 stars, however, they were not able to find right windows so they used one with U value of 1.2, while the actual windows I am planning putting it have U value of below 0.7. And if I left it the way my architect initially designed it, it would quite be hard to push it above 7 stars. Not a lot of architects are capable of designing efficient homes those days, unfortunately. I think what is important is to make sure the house is built to BASIX, this is why I am planning to use infrared camera as well as blower door testing. 9.4!! wow that is impressive. BASIX seems to be a NSW concept though may be region neutral..I'll look into it.. thanks for the suggestion Re: Million dollar home in Perth 31Sep 08, 2020 11:22 am Ok so after weeks of research, meetings and more research, we have selected Riverstone as the builders. The key criteria were Reputation, Past client satisfaction index, Build and design quality , Fixed price contracts, Number of homes built in our budget, Value for money. I assigned points to each of these criterias to get a total score against potential builders , a sort of weighted average. All the names discussed here previously were within 1% of each other in the first four criterion. Riverstone were ahead by about 5% in the last two. While the criterion chosen were impersonal, obviously since I was the one doing the scoring the scores do reflect my personal opinion based on my due diligence. There are two other things which could impact someone's decision One is architect vs draftsman as an in house resource because all of them have outsource architects available if the client needs it but only 3 of them have in house architects and only 1 of them had the architect in the meeting. Second is the cost to the lead up to the signing of the contract varies between 10 to 15% of total build price between builders and since prior to contract signing the banks will not be involved, or in my case they are not, that outlay may be significant. But these two factors did not really matter all that much to me so were not a part of my decision making process. I hope that helps someone out and feel free to PM me with any questions. Once we are at the contract signing stage I shall post back my experience. The property is rented out till April so demolition will happen in May and construction sometime after that. Whoops, asking where you're located, & it's in the title of your thread 😂 If you're planning on having a second living area, I'd probably recommend you locate it… 13 2813 Hi all, we have a home where the main living area and kitchen windows face NW. What should I do to optimise the light and solar principles? It is a renovation so… 0 668 doozer1905 thanks for your input and sorry for late reply!
We have decided against the subdivision due to the time constraint and finances 2 1178 |
