Browse Forums Building A New House 1 Aug 01, 2020 10:42 am I was going through the Vapour Barriers of the NCC (Part 3.2.2.6) which states "The vapour barrier must be placed beneath the slab so that the bottom surface of the slab is entirely under laid and extends under edge beams to finish at ground level in accordance with Figure 3.2.2.3." I am building a house in Victoria and the builder is saying this requirement is not for outdoor living (alfresco) where I noticed the vapour barrier has been allowed to fall down below the finished ground level. Did anyone else notice this for their alfresco? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Vapour Barrier - Slab 2Aug 01, 2020 8:50 pm The builder is correct, doesn't apply to outside concrete or garage concrete Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3805 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9897 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15107 |
