Browse Forums Building A New House Re: what brick company does EB use 2Oct 03, 2008 12:06 pm If they truly are a custom builder, they won't limit you to a manufacturer.
We chose an Austral brick with Binet even though they originally steered us to PGH. They said it didn't matter who we chose, we could to any brick we wanted except handmade stuff. Greg Re: what brick company does EB use 3Oct 03, 2008 12:22 pm Greg - EB aren't custom builders - they are project. After 4 years - we're in! Re: what brick company does EB use 4Oct 03, 2008 12:35 pm stonecutter1309 Greg - EB aren't custom builders - they are project. Greg, stonecutter is right. They are a project home builder & they use PGH & Boral. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: what brick company does EB use 5Oct 03, 2008 3:19 pm Heh, I thought given their prices that they build custom homes. I guess not:)
Greg Re: what brick company does EB use 6Oct 03, 2008 10:58 pm EB uses PGH Bricks & Boral Bricks. We found PGH had a bigger range than Boral. If you tell them that you're building with EB they will provide you with the standard range. They can also provide you with a listing of addresses so you can have a look at a whole house using the bricks you have chosen, sometimes it's a bit hard to decide just by looking at a couple of rows of bricks. I found choosing the bricks the hardest part of the selection process. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8311 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17875 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17539 |
