Browse Forums Building A New House 1 Jul 24, 2020 1:40 pm Hello All We've just heard from our builder about a slight change in the elevation and have been given a couple of options to pick from. Would you recommend cladding or moulding for the front elevation? I am still waiting on the exact material they are going to use but in general want to know the pros and cons. Please see the image below, the cladding/moulding will be the area in light brown with the vertical grooves. Thank you very much in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cladding vs Moulding - Building with Impressions in Pert 2Jul 25, 2020 10:22 am Quite normal thing We built our home with a mix of stone cladding and weather board. Still looks great https://www.instagram.com/p/BuONNDVFbr1 ... ikvx0u64wl Re: Cladding vs Moulding - Building with Impressions in Pert 3Jul 27, 2020 11:45 am jpmontoya Quite normal thing We built our home with a mix of stone cladding and weather board. Still looks great https://www.instagram.com/p/BuONNDVFbr1 ... ikvx0u64wl Thank you very much. When you say weather board, it this the same as moulding? Re: Cladding vs Moulding - Building with Impressions in Pert 4Jul 29, 2020 1:04 pm Our builder has advised that they prefer to use Selekta timber composite cladding for the elevation. Any expert here who can weigh in on the pros and cons of this product? https://www.bluechipgroup.net.au/timber-cladding-perth/timber-composite-cladding-perth.html Thank you very much. Agree, Riviera from Clarendon looks beautiful. I've seen one with a light-colored bricks and just a bit of molding (in my neighborhood). It's definitely overpriced. I'm… 10 6304 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12049 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11117 |
