Browse Forums Building A New House 1 Jul 20, 2020 11:37 am Hello Forum member ! Firstly thanks for all your assistance so far with our floor plan. We are in final stages of the plan and would like your feedback/suggestions for Kitchenette and WIR. As you can see we have a WIR for Bed 2 with dimensions 2.29 x 2.23. we have Sitting on the other side for which I would like to add a kitchenette which I was thinking to reconfigure the WIR2 as we don't need that big WIR. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am struggling to with ideas to convert the WIR2 and was wondering if you can suggest something. In Kitchenette I was looking to install - Small Bar fridge, Sink and space for small sink. If possible a small induction plate. Appreciate your assistance and looking forward to your feedback. Thanks Re: Floor Plan Suggestions 2Jul 20, 2020 3:13 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is the X marked in the WIW ..is it a duct for AC or? first check with the builder if that can be moved ...for a small kitchenette you will need about 65cm width for an under bench fridge, about 30cm width for a single induction plate and about 45cm width for a small bar sink so without the X there's enough space for a kitchen build into a cabinets in a space as small as a wardrobe about 70cm deep with or without enclosing doors....if the X can't be moved then have only a biw in the bedroom and there should be space for a full size narrow fridge and cabinets with sink and cooktop Re: Floor Plan Suggestions 3Jul 21, 2020 9:08 am oklouise Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is the X marked in the WIW ..is it a duct for AC or? first check with the builder if that can be moved ...for a small kitchenette you will need about 65cm width for an under bench fridge, about 30cm width for a single induction plate and about 45cm width for a small bar sink so without the X there's enough space for a kitchen build into a cabinets in a space as small as a wardrobe about 70cm deep with or without enclosing doors....if the X can't be moved then have only a biw in the bedroom and there should be space for a full size narrow fridge and cabinets with sink and cooktop Hi oklouise thanks for the feedback and looks pretty good. The "x" section is the Duct for AC but I can check with the builder if they are really using it and if not then that provides some good space to workaround. I think Option 2 looks good as it provides more space for Kitchenette which can be used for additional storage as well. May be I will add a skylight or a window ( Will try to avoid as it is west facing wall) Appreciate your assistance. Re: Floor Plan Suggestions 4Jul 21, 2020 9:21 am Ozshaz oklouise Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is the X marked in the WIW ..is it a duct for AC or? first check with the builder if that can be moved ...for a small kitchenette you will need about 65cm width for an under bench fridge, about 30cm width for a single induction plate and about 45cm width for a small bar sink so without the X there's enough space for a kitchen build into a cabinets in a space as small as a wardrobe about 70cm deep with or without enclosing doors....if the X can't be moved then have only a biw in the bedroom and there should be space for a full size narrow fridge and cabinets with sink and cooktop Hi oklouise thanks for the feedback and looks pretty good. The "x" section is the Duct for AC but I can check with the builder if they are really using it and if not then that provides some good space to workaround. I think Option 2 looks good as it provides more space for Kitchenette which can be used for additional storage as well. May be I will add a skylight or a window ( Will try to avoid as it is west facing wall) Appreciate your assistance. that sounds good and as long as the AC duct is no bigger than about 60cm x 60cm there should be enough space for a full size fridge or storage next to the AC duct leaving at least 1500 x 2230 for the work area including the counter with sink and a skylight would be better than a window and leave teh whole wall for stoarge shelves or cabinets but if you don't prefer/need a ventilating skylight check out the Solar Skylights (Arcol or Illume brands available from major hardware stores) tehse skylights don't need a hole in the roof (so no risk of leaks) and are easy and cheap to install and ideal for your kitchenette Re: Floor Plan Suggestions 5Jul 21, 2020 11:33 am oklouise Ozshaz oklouise Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is the X marked in the WIW ..is it a duct for AC or? first check with the builder if that can be moved ...for a small kitchenette you will need about 65cm width for an under bench fridge, about 30cm width for a single induction plate and about 45cm width for a small bar sink so without the X there's enough space for a kitchen build into a cabinets in a space as small as a wardrobe about 70cm deep with or without enclosing doors....if the X can't be moved then have only a biw in the bedroom and there should be space for a full size narrow fridge and cabinets with sink and cooktop Hi oklouise thanks for the feedback and looks pretty good. The "x" section is the Duct for AC but I can check with the builder if they are really using it and if not then that provides some good space to workaround. I think Option 2 looks good as it provides more space for Kitchenette which can be used for additional storage as well. May be I will add a skylight or a window ( Will try to avoid as it is west facing wall) Appreciate your assistance. that sounds good and as long as the AC duct is no bigger than about 60cm x 60cm there should be enough space for a full size fridge or storage next to the AC duct leaving at least 1500 x 2230 for the work area including the counter with sink and a skylight would be better than a window and leave teh whole wall for stoarge shelves or cabinets but if you don't prefer/need a ventilating skylight check out the Solar Skylights (Arcol or Illume brands available from major hardware stores) tehse skylights don't need a hole in the roof (so no risk of leaks) and are easy and cheap to install and ideal for your kitchenette Thanks oklouise. I will check with builder if they are using the AC duct. I think they would be to get the AC ducts for the sitting room. The Solar Skylight option is really good one. May be I will get that installed on couple of locations in the house. I like that you don't need the whole cutout in the ceiling similar to skylights. Thanks ! Re: Floor Plan Suggestions 6Jul 22, 2020 5:51 pm Hello Everyone. It would be great to have some feedback about the below kitchen layout. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I was wondering what would be the best way to have Oven Tower at the location highlighted. The limitation is that If we provide oven tower (750mm depth) then the Refrigerator would look very odd. And If i move the Refg. in line with Oven tower i.e. 750mm towards kitchen island then there is no space left between Refg. and Island. Other option would be to move the Island around so that long side faces the Refg. If we move the Refg. front then we can have a dry pantry shelves in the yellow highlighted location. I was looking for any feedback on whats the best configuration around. Thanks! Cheers ! Re: Floor Plan Suggestions 7Jul 22, 2020 6:05 pm there's doesn't look like enough space to have the oven stacked where you've shown but we need accurate dimension of the whole space including kitchen, pantry and powder room as well as the precise size and location of doors and windows including architraves but, is this a new build or a renovation of an existing building?..and what appliances do you need and where would you have them? Re: Floor Plan Suggestions 8Jul 22, 2020 7:07 pm oklouise there's doesn't look like enough space to have the oven stacked where you've shown but we need accurate dimension of the whole space including kitchen, pantry and powder room as well as the precise size and location of doors and windows including architraves but, is this a new build or a renovation of an existing building?..and what appliances do you need and where would you have them? Hi oklouise thanks for the response. Below is the updated layout with dimensions. This would be a new build and I am trying to lock in all the structural changes at this stage. The cooktop in main kitchen is 900mm, in Pantry is 600mm. In the tower there would be 2 ovens 600mm side by side. The layout shows the appliance location. we have servery window in main kitchen near the double sink. Thanks for your feedback. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Floor Plan Suggestions 9Jul 22, 2020 8:58 pm i think the wall ovens would fit so much better along the outside wall but the toilet shouldn't open into the kitchen space but it would be better to see the whole house plan instead of working on separate small sections at a time but my suggestions for the kitchen and pantry allow for more walking space around the island but would prefer to relocate the toilet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Floor Plan Suggestions 10Jul 23, 2020 9:26 am oklouise i think the wall ovens would fit so much better along the outside wall but the toilet shouldn't open into the kitchen space but it would be better to see the whole house plan instead of working on separate small sections at a time but my suggestions for the kitchen and pantry allow for more walking space around the island but would prefer to relocate the toilet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks oklouise. Seems like the best way would be to move the Oven Tower as suggested. In line to what you mentioned I was also thinking to squeeze the Powder room by moving the toilet seat towards left. Not sure how much I can squeeze without making it feel compact. That will create some space along the PWDR back wall but not enough for a tower but may be like a buffet or table. The other way can be to make the island bench more like 2.2x2m which I am assuming will create some space around. But I am not sure how it would look like and if its practical. Any thoughts? Re: Floor Plan Suggestions 11Jul 23, 2020 10:34 am i need to see the whole house plan to respond to your ideas..but, from the little i can see of the floorplan i would be surprised if you would get council approval for a toilet that opens directly into the same room as a kitchen but any changes to one room affects the whole house so it's never a good idea to work on separate rooms when you're planning a new build..share the whole house plans showing dimensions Re: Floor Plan Suggestions 12Jul 26, 2020 2:44 pm oklouise i need to see the whole house plan to respond to your ideas..but, from the little i can see of the floorplan i would be surprised if you would get council approval for a toilet that opens directly into the same room as a kitchen but any changes to one room affects the whole house so it's never a good idea to work on separate rooms when you're planning a new build..share the whole house plans showing dimensions Thanks oklouise appreciate your assistance. we had a few changes to standard plan so it is still being worked upon but I will share it as soon as it becomes available. I really appreciate your feedback. Re: Floor Plan Suggestions 13Jul 26, 2020 2:53 pm We recently had some surveys done and I have tried to put the survey and the sitting plan together to give an overview. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My questions is with regards to a window we have in first floor which faces the backyard neighbours. We wanted to check if we propose a window as highlighted then how the overlooking criteria will affect it. We are in Victoria. Do we need to cover the windows or we should be okay. Please pardon my knowledge but I think the land is sloping diagonally and I think we will have a drop of about 700mm for the build area. Correct ? The rear boundary is 6.66m away and has a colorbond fence of 2.13m height. Appreciate your feedback. Thanks Re: Floor Plan Suggestions 14Jul 27, 2020 3:39 pm Also seeking some feedback from the members if its worthwhile requesting the builder to do a "fill" rather than cut to compensate for the slope? I would like to house sit at the same level with road if not bit higher. Any suggestions if this can be done? Thanks Re: Floor Plan Suggestions 15Sep 01, 2020 3:12 am It seems you didn't get a response? To answer your first question, draw a right angle set of lines, measure up 4.9cm (to represent the 4.9M height that is 1.7M above top floor level). From the ground point, mark 6.6cm and 9cm (represents the 6.66M fence from house wall, and the 9M point that is the overlooking point) from the vertical line. At the 6.66cm point, draw a vertical line up 2.1cm (represents your 2.13M fence. Now from your viewpoint 4.9cm up the first vertical line, draw a line to the ground point 9cm. This line intersects the fence, so there is No overlooking, and you therefore do not require to obscure your windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Floor Plan Suggestions 16Sep 01, 2020 3:14 am In the second, they normally cut and fill across the block (move the dirt from the high side cut to fill the lower point) to make it level for construction. If you are going to just fill, it needs to be compacted, and may also need retaining walls? Re: Floor Plan Suggestions 17Sep 01, 2020 10:25 am Sparkyf It seems you didn't get a response? To answer your first question, draw a right angle set of lines, measure up 4.9cm (to represent the 4.9M height that is 1.7M above top floor level). From the ground point, mark 6.6cm and 9cm (represents the 6.66M fence from house wall, and the 9M point that is the overlooking point) from the vertical line. At the 6.66cm point, draw a vertical line up 2.1cm (represents your 2.13M fence. Now from your viewpoint 4.9cm up the first vertical line, draw a line to the ground point 9cm. This line intersects the fence, so there is No overlooking, and you therefore do not require to obscure your windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Sparkyf thank you very much for the feedback. Looks great. I have also followed your overlooking information on the other topic and seems like I should be okay for the overlooking requirement. Now waiting for the builder's Surveyor to prepare the drawings and confirm from their side as well. Thanks again ! i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17260 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25159 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12484 |
