Browse Forums Building A New House 1 Jul 13, 2020 3:22 pm Hello, has anyone built sunken garage on a sloped block before? I'm curious as to how much additional budget I will need to do something similar to attached. Would imagine there will be additional engineering, site prep + works, retainng wall cost and such. Our street is on the North so I was wondering if it'd be feasible to sink the garage so half of the front is not losing light behind the garage! Any input will be much appreciated - we have chased up the builder but the feedback on the option has been a solid sounding no, so wanted to verify if anyone has done this recently! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cost of sunken garage 3Jul 13, 2020 4:35 pm Hmmm. Its not built like a swimming pool or basement work on $1200 to $1500 m2 here Slab and formwork costs Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cost of sunken garage 4Jul 13, 2020 6:11 pm StructuralBIMGuy Hmmm. Its not built like a swimming pool or basement work on $1200 to $1500 m2 here Slab and formwork costs Cheers Chris Thanks Chris, Is it something builders generally try to avoid doing? I would've thought overall additional cost to sink the garage on the sloping lot would be at most $50k to $100k, but feedback we're getting is that they generally don't do it for houses below 1.5M. Re: Cost of sunken garage 5Jul 13, 2020 7:47 pm We do undercroft garages if the slope of the land dictates Unfortunately you can't avoid it. ie 2->2.5m min. slope I suggest you do the drawings and engineering and find another builder Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cost of sunken garage 6Jul 14, 2020 8:17 am Many new houses around here (Bayside Melbourne) are built with garages like that (or deeper, sometimes a full story below), so it can't be that hard, but it would need some custom design, which I why i suspect cookie cutter type builders won't take it on Re: Cost of sunken garage 7Jul 14, 2020 8:25 am brokenstick .. i suspect cookie cutter type builders won't take it on Correct weight, Most project builders homes are designed and modified by salesman in display homes if you have a difficult build...Caveat emptor Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cost of sunken garage 8Jul 14, 2020 4:09 pm StructuralBIMGuy brokenstick .. i suspect cookie cutter type builders won't take it on Correct weight, Most project builders homes are designed and modified by salesman in display homes if you have a difficult build...Caveat emptor Thanks everyone!!! StructuralBIMGuy - side slope is only ~1.4M over 20M meter and back slope is 1M over 25M so i think the topography doesn't suit, or gets quite expensive if I insist on it! Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9611 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17191 |
