Browse Forums Building A New House Re: Slab engineering for double brick home 6Jul 12, 2020 10:07 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab engineering for double brick home 8Jul 12, 2020 10:40 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab engineering for double brick home 14Jul 12, 2020 4:09 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hope these work? Should be pictures of the geotech report Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab engineering for double brick home 15Jul 12, 2020 4:12 pm alexp79 So double brick or single brick external? Single brick with steel frame where still frame is load-bearing is brick veneer. Double brick (with cavity) is structural construction which is not requiring frame, as the internal leaf acts as load-bearing wall. Site survey indicates the levels across the site as well as your house plan together with site survey should be providing information on the heights of cut and fill required. Also, your developer should be providing compaction report, I believe. Cavity brick around the outside/external basically and then the internal walls will be built with steel frame. Does that make sense? Re: Slab engineering for double brick home 16Jul 12, 2020 4:14 pm What is the contour of your building envelope? Looks like you have around 1 meter of fill only near BH2, but near BH1 and BH3 - everything looks quite ok and natural (even with a good chance to hit a rock when excavating near BH1). Re: Slab engineering for double brick home 17Jul 12, 2020 4:16 pm ReneeN alexp79 So double brick or single brick external? Single brick with steel frame where still frame is load-bearing is brick veneer. Double brick (with cavity) is structural construction which is not requiring frame, as the internal leaf acts as load-bearing wall. Site survey indicates the levels across the site as well as your house plan together with site survey should be providing information on the heights of cut and fill required. Also, your developer should be providing compaction report, I believe. Cavity brick around the outside/external basically and then the internal walls will be built with steel frame. Does that make sense? Got it. Internal walls will be built using steel studs. So your house is full masonry and this is why engineer specified deeper footings. Will you be able to provide engineering drawings for your footings? Re: Slab engineering for double brick home 18Jul 12, 2020 5:07 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ These are the drawings from the engineer Re: Slab engineering for double brick home 19Jul 12, 2020 5:08 pm alexp79 What is the contour of your building envelope? Looks like you have around 1 meter of fill only near BH2, but near BH1 and BH3 - everything looks quite ok and natural (even with a good chance to hit a rock when excavating near BH1). I’m not entirely sure, would that be something done from a surveyor? We didn’t get that done it wasn’t indicated as needed. I can attach a photo of the building pad? Re: Slab engineering for double brick home 20Jul 12, 2020 7:00 pm AS2870 and AS4773.2 are copyright Australian Standards so you will need to buy them
https://www.techstreet.com/sa/standards ... id=2048299 https://www.techstreet.com/sa/standards ... id=2068452 or head across to the Steel Reinforcement Institute of Australia website https://www.sria.com.au/downloads.html and download this presentation https://www.sria.com.au/LiteratureRetrieve.aspx?ID=199666 which probably has enough detail for you. Take a look a Page 54 and you will your slab itself looks consistent with a Class M / Articulated full masonry construction (albeit with 3-L12TM in your case) As per the other opinions expressed, if it was for my house, I would query the number of piers proposed. Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31780 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14627 5 10459 |
