Browse Forums Building A New House 1 Jul 07, 2020 1:11 am Hi, we have just completed our brickwork and I am not satisfied with the alfresco area. In the plans we had the column sitting on the slab but as the pic below shows some of it is sitting on the edge. I have mentioned it to supervisor and he said we will be doing a thorough inspection in a few weeks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Manhattan 44 build with wisdom 4Jul 07, 2020 3:14 pm shuru81 you are entitled to recieve exactly what was detailed and agreed on on your contract plan. This error simply needs to be fixed, and any design and construction dependencies addressed appropriately. Please note, it is not the site supervisors' job to check for conformance to plan or quality of workmanship, despite what he wants you to think. His job is primarily to keep the construction project moving and your progress payments coming therefore he will tell you anything to achieve this. Unfortunately checking the works is your responsibility. Make sure every correspondence about this issue is documented in writing in case you experience avoidance, push back or other tactics. Keep them honest by sharing your experiences about this issue with other members here. Don't be persuaded to keep this private. Re: Manhattan 44 build with wisdom 5Jul 07, 2020 3:27 pm Thanks so much! I assumed site supervisor would check things. But we have an independent company who will come and check thing prelining stage. I will wait till we do the walk through to raise it. It’s quite disappointing but I will follow it up. Re: Manhattan 44 build with wisdom 6Feb 25, 2021 5:12 pm thanks for sharing this, were you able to resolve this issue with Wisdom Homes? we're considering them for our knock down rebuild and doing a bit of research on their workmanship and overall customer satisfaction so your feedback is reallhy helpful. Hi all, Due to new building grants, myself and my partner have decided to take the plunge and build our first home. We're going through Homestart in Perth (we live… 0 505 I built the Ambassador 36 as well and it's in the construction plan. Is it those green steel beams or meant to be in addition to them? 2 1304 Good choice between these two builders. I know the management of both and they are all nice people for what that is worth. I personally think Wisdom are building some… 1 1573 ![]() |
