Browse Forums Building A New House 1 Jul 06, 2020 10:45 am Hi all, Just planning my own home. I've been designing it in Sketchup and have settled on a design that is going to be at least very close to our final design. It'll be on stumps roughly 1m from ground to bottom of the bearer. I'm now working out material costs for the main structure so I can get some idea on materials costs and their pro's and con's. One thing I haven't yet decided on is steel vs timber for the subfloor. For example, engineered lumber seems like the way to go if you want to aim for tighter tolerences and go for longer spans, but I'm a bit dubious about using engineered timber for the bearers do to the fact that they're likely to be exposed to water during weather events, sprinklers, etc. Steel Universal Beams seem like a good option for the bearers, and would allow me to get away with having less stumps. Not sure about steel joists though; may as well still with an LVL for that. I just wanted to get some opinions/advice from people who have experience with both steel and timber subfloors, or mixing the two. Cheers Re: Steel vs Timber for Subfloor 2Jul 06, 2020 11:17 am Hi Wardrop Search the internet... it's full of marketing, pros and cons What you won't find is design Information of your specific Build So if you require a better reply, put up more information ie, your sketchup model generally, the better the information the better the reply and it helps others Track down the respective certified engineering for Subfloor systems, use 3D components,quantify, don't bother modelling 3D nuts and bolts,etc,etc Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi Vlad, everything is not a negative for steel frames else the matkwt woukd nit have so many Steel Frame houses and mind you till a few years back and even today in… 6 1538 Revised plan has support where the bifolds meet in the corner. The posts are now 150mm and where I would like them. 150mm timber would look pretty cool, but I'm still… 6 2823 Building Standards; Getting It Right! handymanny At a glance the joist beams have deflected, possibly undersized ? so refer back to the engineering drawings Unfortunately no easy fix as they may need to be… 1 945 ![]() |
