Browse Forums Building A New House 1 Jul 01, 2020 7:28 pm Hi All, Just wondering if anyone knows if i can add a fireplace downstairs after handover? Or did i need to make sure there was some sort of provision made for it first. Im not even sure what type of fireplace. Its just an idea at this point! Thanks Re: Fireplace 2Jul 01, 2020 7:31 pm There are moves to make their use illegal. Will it be purely for aesthetics? 3in1 Supadiverta. Best Practice Rainwater Harvesting using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Fireplace 4Jul 01, 2020 8:41 pm You would need to provision a flue and gas connection (if you are going with gas) but also there are flue less options, in that case you don't really need any provisions. Alternatively, you can consider much cheaper "emulator" fireplace which is a TV with built-in heater which is showing you burning fire picture and playing relevant sounds too. Re: Fireplace 5Jul 02, 2020 9:42 am ![]() You would need to provision a flue and gas connection (if you are going with gas) but also there are flue less options, in that case you don't really need any provisions. Alternatively, you can consider much cheaper "emulator" fireplace which is a TV with built-in heater which is showing you burning fire picture and playing relevant sounds too. Just to add on the question, can an electric fireplace be installed after handover ? What provisions needs to be done during construction ? Thanks Re: Fireplace 6Jul 02, 2020 1:50 pm ![]() ![]() You would need to provision a flue and gas connection (if you are going with gas) but also there are flue less options, in that case you don't really need any provisions. Alternatively, you can consider much cheaper "emulator" fireplace which is a TV with built-in heater which is showing you burning fire picture and playing relevant sounds too. Just to add on the question, can an electric fireplace be installed after handover ? What provisions needs to be done during construction ? Thanks For electrical fireplace you would need a niche in the wall to fit as well as power point in that niche. You can also install it into a separate frame in front of the existing wall, too, but in that case you would have to sacrifice some floor space. FEDERATION FIREPLACE COVERED UP??? Our 100 + year old home has a fireplace changed somehow by previous owners. It looks like its been rendered. It had marble and cedar… 0 584 My thoughts exactly. Get a double between dining/media. Will look amazing 5 1114 ![]() We had a real flame landscape, in our last house which we loved, we were going to put in an Escea this house until we found the real flame landscape was being discontinued… 6 1501 ![]() |
