Browse Forums Building A New House 1 Jun 26, 2020 9:24 pm Would like some feedback / thoughts on two builders construction notes. Which is better? Can you even compare? Both: Roof Trusses at 600mm centres - Tiled Roof @ 20 Degree Pitch Builder 1 STUDS LOAD BEARING WALLS (BASED ON MAXIMUM TRUSS SPAN OF 9000mm) BOTTOM PLATE - 2/45 x 90 MGP12 TOP PLATE - 2/45 x 90 MGP12 COMMON STUDS - 45 x 90 MGP10 AT 450 CENTRES NON-LOAD BEARING WALLS BOTTOM PLATE - 2/45 x 90 MGP10 (A.S. 1684) TOP PLATE - 2/45 x 90 MGP10 (A.S. 1684) COMMON STUDS - 45 x 90 MGP10 AT 450 CENTRES (A.S. 1684 NOGGINGS MINIMUM 35 x 90 MGP10 AT MAXIMUM 1350 CRS MAX. 19MM THICK YELLOW-TONGUE SHEET FLOORING THRU-OUT. Builder 2 FRAME SPECIFICATION • Frame timber to be MGP 10 pine. • 90mm x 45mm bottom plate. • 90mm x 45mm top plate. • 90mm x 35mm pitching plate to top plate for truss bearing to external walls. • 90mm x 35mm window sills. • 90mm x 35mm door and window heads. • 90mm x 35mm common studs @ 450mm centres to single storey or upper storey. • 90mm x 45mm common studs @ 450mm centres to lower storey of 2 storey. • 90mm x 45mm, 2/90mm x 35mm, 2/90mm x 45mm jamb studs. • 70mm x 35mm noggings. FLOOR SPECIFICATION (suspended sub-floor) • 19mm particle board flooring to all areas. •140 x 45 MGP10 floor joists @ 450mm centres - as per engineers design • 90 x 45 MGP10 joist blocking under external load bearing walls • 2/140 x 45 MGP10 bearers @ max. 2200mm centres. - as per engineers design (joists & bearers based on continuous spans.) Re: Frame Specs Comparison 3Jun 27, 2020 8:53 am Cheech74 Welcome to the forum Builder 1 is typical of a builder that specifies up grades even if it's not required Builder 2 is typical min standards .. as per Engineer. Builder 3? will explain why its necessary and minimise $ticker$hock lol..Sounds like a sales promotion comedy act The key is the certified engineering plans Ignore the builders sales BS Builders have a tendency to bump engineering costs after you are locked in and clients think/trust it's the norm. Always ask for engineers data and proofs..have it explained BTW Engineering 3D Bim is a great way to explain/learn Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I've gone for pre-fab walls. I did it because I wanted to remove the idiot factor from the construction on site , control theft and reduce waste plus its supposed to be… 10 42297 The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 20801 ![]() Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! 6 20113 ![]() |
