Browse Forums Building A New House 1 Jun 09, 2020 1:46 pm Hi, We have a block of land which is listed as being in a mine subsidence area. It has been given 'Guideline 2' restrictions. Part of Guideline 2 says that the structure has to be no more than 24m long. You can go over 24m, but your plans need to be approved 'on merit' by the Mine Subsidence Board. We are planning for a house around 37.2m wide on the land. Has anyone built in a mine subsidence area and have had to go through this merit approval system? Any feedback would be greatly appreciated. I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3232 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6242 |
