Browse Forums Building A New House 1 May 27, 2020 7:01 am Hi All, is there a legislation that states excavation done on your land should be supported on your land? We are in the situation where my builder cut our land by 564mm. Our land is small, 300m2, so the cut extends to the fenceline boundary. In the initial plan that went out for review, there was retaining wall In the boundary. This was subsequently removed because there is an easement 900mm wide from the fenceline to the external wall of our house. Our side access is 1.35m wide and easement is 900mm so we only have 450mm to work on. We can’t put the wall on 450mm space as it won’t comply with the 900mm side setback. We also can’t build the wall on the boundary because we have the neighbour’s zero-boundary garage on natural ground level. My understanding there was a negligence on on my builder side for not altering the cut/fill after the retaining walls were removed. I want to press on but I need to quote legislation if there is any. I already went to council to have walls approved but it was rejected. Re: Legislation on supporting excavation 2May 27, 2020 7:29 am Sounds like a case of mistakes all-round which could have been fixed if the proper engineering Details were certified. Alas people make mistakes, and clients building generally pay dearly? Unfortunately, being in NSW, Taking on the builder and council means your off to court. In WA you would lodge a complaint with the WA Building Commission and State Administrative Tribunal Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Legislation on supporting excavation 3May 27, 2020 11:59 am Thank you for your reply. I am hoping it does not get there. So for now, I am just looking for solid legislation I can probably quote to the builder. As of the moment, they kept on telling me that they were compliant and so are not to be blamed. Re: Legislation on supporting excavation 4May 27, 2020 8:00 pm StructuralBIMGuy Alas people make mistakes, and clients building generally pay dearly? Re: Legislation on supporting excavation 5May 28, 2020 8:38 pm That SEPP link I posted in response to your other query covers this in relation to CDC. Your builder might just say it’s was a temporary construction measure. That would be compliant. Re: Legislation on supporting excavation 6May 30, 2020 6:47 am worldofmud That SEPP link I posted in response to your other query covers this in relation to CDC. Your builder might just say it’s was a temporary construction measure. That would be compliant. Thank you for your reply. Thats what they keep on saying back to me - it was compliant during the build. They are also saying that the neighbour’s cut was not beneficial for me. Whereas, the neighbour maintained his garage on NGL. Mine was cut but no provision for support. It’s Like we were relying on the neighbours to be able to support our land. Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4242 Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7850 No one can give you a meaningful answer without looking at your building contract, what happened on site and who designed your house You should get experienced building… 1 10202 |
