Browse Forums Building A New House Re: Which floor plan is better? 6May 21, 2020 12:17 pm The one on the left is better, all the bedrooms but for the master would receive good light & warmth. Are you too fussed about having an alfresco ? If not, you can have a grand living area by combing the alfresco area into the house floor area. You can have a pergola built later. Re: Which floor plan is better? 7May 21, 2020 2:59 pm Ashrodan After first studying the right side, I quickly liked the left one. It feels more spacious with better flow and less walls. You get a study which is great. Only issue I see is that laundry is right on the living tv area which could be annoying I'd the washing machine is on Thanka for the suggestion. Builder confirmed i can switch laundry and study at no cost. Re: Which floor plan is better? 8May 21, 2020 3:01 pm The only thing thats stopping me from choosing the left one is that the masters bed seems small. Ive asked if they said they can only make it 450mm longer but not wider..they cant relocate the ensuite Re: Which floor plan is better? 9May 21, 2020 3:36 pm Love the flow of the left Building Grange 22 by Coral Homes in QLD -> https://forum.homeone.com.au/viewtopic.php?f=31&t=97426&p=1860633#p1860633 Re: Which floor plan is better? 12May 22, 2020 8:21 am Building Grange 22 by Coral Homes in QLD -> https://forum.homeone.com.au/viewtopic.php?f=31&t=97426&p=1860633#p1860633 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7575 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 688 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7274 |
