Browse Forums Building A New House 1 May 20, 2020 12:34 pm Hi everyone As it stands in our current plans, we don't have access to our rear yard via the garage. We can enter the home via the garage and walk through the laundry for access to the side of the home, or enter the rear yard from the front yard via the other side of the house. How important do you think is rear access direct from garage? Just trying to fit everything in on a small block! Thanks in advance. Re: Rear access from Garage 2May 20, 2020 3:52 pm I personally wouldn't worry about it, as long as you have access on the other side of the house. We deleted our garage rear P/A door, mostly to save ~$380, but also it takes away some wall space in the garage for storage etc. We also have a rear shed though (corner block) so that might be a factor. But as long as you can move a lawn mower etc around via the other side to the rear then it shouldn't be an issue. --------------------------------------------------------------------- Check our Homeone build blog here Re: Rear access from Garage 3May 21, 2020 1:40 pm If at all possible to have it, I would. We use ours a lot. We can walk around the other side or through the house, but that would drive me nuts. I feel like it would be one of those small decisions that you regret. Like me not adding a 3rd out side tap near the laundry just to save a few hundred, silly mistake. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8462 |
