Browse Forums Building A New House Re: Backfill around the concrete slab 3May 19, 2020 11:33 pm ![]() if it is slab on ground it should be kept visible as a termite barrier, is this what you mean? Yes. I’m just wondering if I can go back to the builder to fix this quoting Au standards or best practice. Hi, I'm not sure whether this is the correct forum for my question. Our townhouse is built on a slightly sloping block. At the back of the house is a timber deck on… 0 2392 Also, your main savings will be coming from cost of renting the pump and minimum order for the concrete. 2 4079 Are those "all in" costs including earthworks, set out, plumbing? If it is just for formwork, reo, concrete and finish then probably a bit on a high side. If it… 3 1398 |
