Browse Forums Building A New House 1 May 19, 2020 10:59 pm Hi, We are nearing our PCI For our split-level house. Our perimeter has been backfilled but I just noticed that the footings on the lower level are buried and no longer visible. I just want to know if this is a defect that I can ask the builder to rectify? What is the AU standard for backfilling around the slabs? How do we measure enough backfill? I have a feeling that the backfill was made to make it very close to the level of my neighbour’s Zero-lot garage. But in effect my footings are buried and so are part of my bricks. Thank you in advance! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Backfill around the concrete slab 3May 19, 2020 11:33 pm ![]() if it is slab on ground it should be kept visible as a termite barrier, is this what you mean? Yes. I’m just wondering if I can go back to the builder to fix this quoting Au standards or best practice. Hi, I'm not sure whether this is the correct forum for my question. Our townhouse is built on a slightly sloping block. At the back of the house is a timber deck on… 0 2392 Also, your main savings will be coming from cost of renting the pump and minimum order for the concrete. 2 4079 Are those "all in" costs including earthworks, set out, plumbing? If it is just for formwork, reo, concrete and finish then probably a bit on a high side. If it… 3 1398 |
