Browse Forums Building A New House 1 May 19, 2020 4:18 pm Hi There, We are building in Perth for the first time and have 2 awesome concept plans and we are seeking feedback because we are totally confused! Option 1 - has the rear living that we’ve always visualised but as this faces south we are worried it will be cold. We love the kitchen, scullery in this design. Option 2 - will the alfresco be too hot because it faces West? We love the separation between our room and the kids rooms in this. Also trying to take advantage of the sea breeze blowing in from the south west (Fremantle Doctor). What do you guys think? Thanks in advance! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: House plan Feedback Please - Option 1 or 2?!? 2May 19, 2020 4:29 pm Probably makes sense to put swap your Living with Master in Option 2. Alfresco is covered and will be also shading out your Master from the West side in that case (this is what alfrescos for). I am also thinking that this huge corridor window near guest room/laundry ideally needs to be shaded off with some kind of awning and should be using Low E glass (same as your kitchen window). Re: House plan Feedback Please - Option 1 or 2?!? 3May 19, 2020 4:35 pm ![]() Probably makes sense to put swap your Living with Master in Option 2. Alfresco is covered and will be also shading out your Master from the West side in that case (this is what alfrescos for). I am also thinking that this huge corridor window near guest room/laundry ideally needs to be shaded off with some kind of awning and should be using Low E glass (same as your kitchen window). Thanks for the reply. Definitely worth considering, I've never had a living area at the very front of a house so I have to think about privacy - we aren't one to keep curtains/shutters closed etc as we like as much light and air as possible. Thanks again, I appreciate it. Re: House plan Feedback Please - Option 1 or 2?!? 4May 19, 2020 4:54 pm The one thing that never makes sense to me on a lot of plans is having a media room right next to another living room. Do you ever expect these to be used at the same time? Because otherwise it will just be a cacophony of competing noise. Re: House plan Feedback Please - Option 1 or 2?!? 5May 19, 2020 5:00 pm ![]() The one thing that never makes sense to me on a lot of plans is having a media room right next to another living room. Do you ever expect these to be used at the same time? Because otherwise it will just be a cacophony of competing noise. Good point - yes they will often be used at the same time as we use both rooms frequently. The media room will be noise proofed but I know this will never block out all sound. We had asked for the media room to not be next to any bedrooms. Thanks for that, something I’ll add to my list for further consideration Re: House plan Feedback Please - Option 1 or 2?!? 6May 19, 2020 5:40 pm ![]() ![]() The one thing that never makes sense to me on a lot of plans is having a media room right next to another living room. Do you ever expect these to be used at the same time? Because otherwise it will just be a cacophony of competing noise. Good point - yes they will often be used at the same time as we use both rooms frequently. The media room will be noise proofed but I know this will never block out all sound. We had asked for the media room to not be next to any bedrooms. Thanks for that, something I’ll add to my list for further consideration Yeah, we sound proofed ours as well - but it's also at the other end of the house to the other living area. It'll be the pocket doors that are the weak point because you can't insulate those walls unless it's external to the cavity, and then the doors themselves. Re: House plan Feedback Please - Option 1 or 2?!? 7May 19, 2020 7:21 pm So, you need to think about the practicality of the design. For instance, bringing groceries in from the car into the kitchen is a much more difficult task in the first layout. But I think the first plan has better/more storage areas. Orientation wise, is plan 2 better flipped? Re: House plan Feedback Please - Option 1 or 2?!? 8May 19, 2020 7:32 pm ![]() So, you need to think about the practicality of the design. For instance, bringing groceries in from the car into the kitchen is a much more difficult task in the first layout. But I think the first plan has better/more storage areas. Orientation wise, is plan 2 better flipped? Thanks for the reply. I also thought about flipping plan 2 but we have a large double storey home on our eastern side and I don’t want the pool to be overlooked by them. Good thinking with groceries, I didn’t think of that. I’m not sure that would be a deal breaker though if it achieves that seamless indoor/outdoor kitchen and living we want. But it does remind me that I really need to think about how we would live in each design. Thanks ![]() The first question most experienced people ask is which way is North? It doesn’t seem you can exit your laundry directly outside? Agree with amilelka, about the… 2 1028 ![]() Thank you for that, it certainly makes a lot neater and clearer. They have a process here including going through a design stage, survey, contour plan, bush fire, waste… 8 4138 Not a bad layout but your draftie needs to go back to school. God those leader lines. 1500wide entry hall is a massive waste in my opinion. Give more to the guest room… 4 885 ![]() |
