Browse Forums Building A New House 1 May 18, 2020 12:11 pm Re: Water Pool on Slab 2May 18, 2020 5:22 pm KameGame Should not be a concrete issue as the slab would have been left to 'cure' well before they started the framing. Pooling maybe an indication the slab is not level though. If you can easily check it for standards tolerance with a 1.8m or 2m straight edge / spirit level and window packers or a small ruler. If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12161 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 19014 Just removed 40 liters of water in the span of 2 hours. Water fills up the hole just above the seepage point and doesn't overflow. 1 967 |
