Browse Forums Building A New House Re: CCTV on a new built house 11May 14, 2020 12:07 pm supersleuth If you are running cat 6 cable for future cameras just make sure your on top of site supervisor to pull through soffits. I ran all my cables for 8 cameras, drew diagrams where to pull through and the chippies still forgot to pull through. So now I either have to cut a large hole in soffit to reach in and grab it, or unscrew and lift of the roof -either way is a PITA. Re: CCTV on a new built house 12May 18, 2021 7:08 pm Jayjay84 I asked the builder to install all the cat6 wiring for all 8 of my future cameras. Cost me 400. When I moved into the house electrician just hooked the cameras up. He said if the wiring wasn’t there would have been very hard and time consuming especially for cameras downstairs. Worth getting the builder to do the wiring and terminate into one point like the study etc which builder was it/ Carlisle homes is charging me around 1k for 7 data points and some weather proof enclosures Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20677 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12749 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4194 |
