Browse Forums Building A New House 1 May 04, 2020 9:27 am Hi guys. Just wondering about the actual building process and having inspections done. In Qld, who inspects and certifies the build especially the pre pour slab stage, is it the external consultant (engineer) who was contracted by the builder to design the footings or builder can appoint their own or from the council? I’m confused about if whether the required process is whoever is the structural engineer who design the footings, he should be the one to inspect it and give certification, that’s what I think should happen, but is that the case? I would like if the engineer who designs it will inspect it and even more supervise it. Am I allowed to contact the structural engineer and request them to supervise at my own cost? What is the estimate cost of this? If I hire a building inspector at each stage, and for example they find mistakes especially at pre slab stage, can I get their findings to the builder to correct, what grounds do I have to get them to correct it if it has been signed off by their certifier? Basically, I want to make sure they get it right at foundations so I would like the structural engineer to inspect. Please confirm if engineer do come and inspect the build first before slab stage?? Thanks a lot Re: Who certifies the build? 2May 04, 2020 11:28 am Building Surveyors(BS) can only certify the work as per the NCC If the build details are different chances are it is an alternate solution or worse....unsafe rubbish? Structural engineers certify alternate Solutions as "fit for purpose" and unsafe structural elements as "Not fit for purpose" The problem arise when the tradie/builder/ inspector or BS says it's an acceptable alternate Solution when it's not and you won't know if it's unsafe Structural elements ie footings, beams, suspended slabs etc should always be inspected by your own Independent Engineer OT The builders engineer is instructed, what to check and is paid accordingly, who checks the structural items/things that aren't paid for? I suggest you check with your Council Building department BTW the smart money is on taking the right photos, asking qualified professionals questions before the work is completed and covered up and always give the builder sufficient notice of inspections prior, in case the structural concrete work has to be halted, no one likes having to turn back a concrete truck during a pour. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Who certifies the build? 3May 04, 2020 11:56 am Thanks Chris for your input. So let me clarify, I need to get an independent structural engineer on top of the builder’s engineer? If for example the independent engineer I hired finds issues with the structural elements, is the builder obligated to fix it even if they have their own engineer? Thanks.. I will call our local council building dept to inquire.. Re: Who certifies the build? 4May 04, 2020 12:36 pm ![]() I will call our local council building dept to inquire.. Good move and ask them what hasn't the builders engineer provided/certified? OT I bet the Unit owners of Opal Towers knowing what they know now, would have also wanted their own Independent engineers certifying the structural elements/build here Opal Builder structural failure Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Who certifies the build? 5May 04, 2020 1:50 pm If you have had to get a seperate Geotech report it’s normally the Geotech who provides certification of the ground conditions for footings. If no Geotech was required I think the builder or Structural Eng. can sign off. Either way it should be on the first page under ‘Foundation’ or ‘Footings’ of the for construction structural drawings. Get it right because retrospective footing sign offs are a pain and can be costly. We are building with Eight homes, 42squ. just cut the site, we spent $74K over the list price however around 30k of that was site costs, including 14k site, 6k location… 3 1875 Hi Kumar I’ll message you privately my details Thanks 5 1531 ![]() Looks like they forgot the flashing. Your builder should rectify at their cost. 2 1894 ![]() |
