Browse Forums Building A New House 1 May 13, 2020 11:01 am Hi, just want some advise.
I am building a two-storey house and should I install CCTV with the builders? or is this cheaper to do it after handover? The builder quoted $3373 for 4 cameras and 1 intercom (installed), not sure about the brand and the quality as I'm yet to get an answer from them about this. Should I just tell the builders to initiate a point for "future" cameras and I can call a technician to do this CCTV installation? How much does intalling cameras cost if I buy my own CCTV? Thanks. Re: CCTV on a new built house 2May 13, 2020 11:44 am I asked my builder to install the intercom, however, I had the cat 6 cable roughed in for 6 to 8 cameras which I will install at a later date. Re: CCTV on a new built house 3May 13, 2020 11:49 am Just buy ring stickups and doorbell. I was in the same situation six months back, turned down builders offer for around $3k and instead installed myself 2 stickups and 1 doorbell under $1k. No wires, and works like a charm. good thing is you can fit anywhere you like and change the location as well if you need. Everyone sells it, Bunnings, HN, JB-HiFi etc. https://au-en.ring.com/ Re: CCTV on a new built house 5May 14, 2020 10:02 am I asked the builder to install all the cat6 wiring for all 8 of my future cameras. Cost me 400. When I moved into the house electrician just hooked the cameras up. He said if the wiring wasn’t there would have been very hard and time consuming especially for cameras downstairs. Worth getting the builder to do the wiring and terminate into one point like the study etc Re: CCTV on a new built house 6May 14, 2020 10:09 am It's not hard to rough in yourself. Just go to wholesaler and get a box of cat 6 cable 305m and then work out where your NVR box will be and then run a single cable from that to every camera location. If you can also run a cable from the NVR to where the telephone/router box will be. Also while you are at the wholesalers grab some cable clips to clip all the cables in nicely in the roof. Re: CCTV on a new built house 7May 14, 2020 10:43 am ![]() Just buy ring stickups and doorbell. I was in the same situation six months back, turned down builders offer for around $3k and instead installed myself 2 stickups and 1 doorbell under $1k. No wires, and works like a charm. good thing is you can fit anywhere you like and change the location as well if you need. Everyone sells it, Bunnings, HN, JB-HiFi etc. https://au-en.ring.com/ Ring is good for retro fit and if you don’t mind your images being sent to the cloud. If you have access to run cables a hardwired solution with local storage is far better. I myself have a UniFi system. Re: CCTV on a new built house 8May 14, 2020 10:53 am ![]() ![]() Just buy ring stickups and doorbell. I was in the same situation six months back, turned down builders offer for around $3k and instead installed myself 2 stickups and 1 doorbell under $1k. No wires, and works like a charm. good thing is you can fit anywhere you like and change the location as well if you need. Everyone sells it, Bunnings, HN, JB-HiFi etc. https://au-en.ring.com/ Ring is good for retro fit and if you don’t mind your images being sent to the cloud. If you have access to run cables a hardwired solution with local storage is far better. I myself have a UniFi system. Do you need the provisions for the cables to install UniFi system? or is it a stick on like Ring? Re: CCTV on a new built house 9May 14, 2020 11:14 am [quote="cs212":35exek0r][quote="AJW":35exek0r][quote="ligongl":35exek0r]Just buy ring stickups and doorbell.
I was in the same situation six months back, turned down builders offer for around $3k and instead installed myself 2 stickups and 1 doorbell under $1k. No wires, and works like a charm. good thing is you can fit anywhere you like and change the location as well if you need. Everyone sells it, Bunnings, HN, JB-HiFi etc. [url=https://au-en.ring.com/:35exek0r]https://au-en.ring.com/[/url:35exek0r][/quote:35exek0r] Ring is good for retro fit and if you don’t mind your images being sent to the cloud. If you have access to run cables a hardwired solution with local storage is far better. I myself have a UniFi system.[/quote:35exek0r] Do you need the provisions for the cables to install UniFi system? or is it a stick on like Ring?[/quote:35exek0r] UniFi you need to cable it. But that was my point if you have access to run cables then in my opinion it is the best way to go. Re: CCTV on a new built house 10May 14, 2020 11:39 am If you are running cat 6 cable for future cameras just make sure your on top of site supervisor to pull through soffits. I ran all my cables for 8 cameras, drew diagrams where to pull through and the chippies still forgot to pull through. So now I either have to cut a large hole in soffit to reach in and grab it, or unscrew and lift of the roof -either way is a PITA. Re: CCTV on a new built house 11May 14, 2020 1:07 pm ![]() If you are running cat 6 cable for future cameras just make sure your on top of site supervisor to pull through soffits. I ran all my cables for 8 cameras, drew diagrams where to pull through and the chippies still forgot to pull through. So now I either have to cut a large hole in soffit to reach in and grab it, or unscrew and lift of the roof -either way is a PITA. Thanks guys. I might do it after handover since I was told I need to have internet connection for the NVR setup. 3 1193 Hi everyone we are looking at upgrading our home CCTV setup We had a system installed a few years back Its a Dahua 8 channel DVR XVR5108HS And we are running 8… 0 2035 ![]() There have been a lot of corners cut with out build and the rectification works are worse than the initial issue. Make some calls today to some NATHERS experts who have… 6 1467 |
