Browse Forums Building A New House Re: Building a Doulton in Geelong 141Jul 07, 2021 9:14 pm viewtopic.php?p=1892503#p1892503 Yes, quite correct, despite the photo being a bit blurry! One of many items picked up by Darbecca today! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a Doulton in Geelong 144Jul 13, 2021 10:17 pm There is insulation in the ceiling, walls, and we have double glazing. Re: Building a Doulton in Geelong 145Jul 13, 2021 10:21 pm Sparkyf There is insulation in the ceiling, walls, and we have double glazing. Thanks for the reply.Hope they are stock standard insulation. Would you be able to share type of heating and cooling system younhave gone with? Re: Building a Doulton in Geelong 146Jul 13, 2021 10:33 pm $3K credit on the ducted gas heating, as we changed to Daikin FDYQN250 reverse cycle ducted 10 zone split system, about $25K. We are having a solar system to offset some of the running cost of that too! Your requirements might be different, which house and size are you planning? Re: Building a Doulton in Geelong 147Jul 13, 2021 10:36 pm Sparkyf $3K credit on the ducted gas heating, as we changed to Daikin FDYQN250 reverse cycle ducted 10 zone split system, about $25K. We are having a solar system to offset some of the running cost of that too! Your requirements might be different, which house and size are you planning? I am split between Doulton 50 and Astoria Grand from Carlisle. Thanks again. Re: Building a Doulton in Geelong 148Jul 13, 2021 10:42 pm I think it was Carlisle that said they couldn't build on our block, as the slope was greater than 1M! They have some nice houses too! Re: Building a Doulton in Geelong 149Jul 13, 2021 10:46 pm Sparkyf I think it was Carlisle that said they couldn't build on our block, as the slope was greater than 1M! They have some nice houses too! Doulton 50 is very tempting as its standard floor plan is very nice. Carlisle also good but may need alteration to suit us. Carlisle inclusions are neat and clear. Base price for Doulton is 480K. But I am concerned about addons on rop of it. Re: Building a Doulton in Geelong 150Jul 13, 2021 10:52 pm The staircase sold us on the Doulton, but we have easements and overlooking issues, so we couldn't build the 56. That in addition to a 3.2M corner to corner slope..... they even said no to extending the alfresco on the 50, as the soil thickness would be too much under the slab! Re: Building a Doulton in Geelong 151Jul 14, 2021 10:27 am Sparkyf The staircase sold us on the Doulton, but we have easements and overlooking issues, so we couldn't build the 56. That in addition to a 3.2M corner to corner slope..... they even said no to extending the alfresco on the 50, as the soil thickness would be too much under the slab! Similar story for us. But even after we had the site cut and levelled, both Carlisle and Porter Davis both said they don't do battleaxe blocks. Otherwise I might be living in a Carlisle Montpellier 51 like they have on display at Clyde North. Re: Building a Doulton in Geelong 152Jul 20, 2021 6:08 pm Was it due to limited access for construction? Re: Building a Doulton in Geelong 153Jul 21, 2021 4:26 pm All defects rectified (except three at this stage). One is for the termite barrier to be fixed where they penetrated with pipes. The others are an overhanging frame and misplaced pipe! But at least they are getting things done, not affected by lockdown! Re: Building a Doulton in Geelong 155Jul 21, 2021 5:55 pm Sparkyf All defects rectified (except three at this stage). One is for the termite barrier to be fixed where they penetrated with pipes. The others are an overhanging frame and misplaced pipe! But at least they are getting things done, not affected by lockdown! Good going. Re: Building a Doulton in Geelong 156Jul 22, 2021 12:26 pm Sparkyf Was it due to limited access for construction? Yep I think that was the main reason. Re: Building a Doulton in Geelong 157Jul 22, 2021 12:36 pm Sparkyf All defects rectified (except three at this stage). One is for the termite barrier to be fixed where they penetrated with pipes. The others are an overhanging frame and misplaced pipe! But at least they are getting things done, not affected by lockdown! Wow!! Thats awesome bro! Re: Building a Doulton in Geelong 158Jul 23, 2021 12:01 am Re: Building a Doulton in Geelong 159Jul 23, 2021 9:14 am Sparkyf Wow!! Thats awesome bro! Here is the list currently: [/quote] Did you ever hear back from the metricon certifiers as to why they did not pick these defects in the first place? Re: Building a Doulton in Geelong 160Jul 23, 2021 7:39 pm No. It sort of indicates favouritism or company in the back pocket. They get paid regardless, so I guess if they don't find "issues" then it's less expenses for the builder. Maybe someone gets a kickback? Or maybe corruption is rife? Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10741 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110565 |
