Browse Forums Building A New House 1 Mar 20, 2020 6:15 pm Hoping someone can explain to me something as I feel like Ive been taken for a ride. Long story short we failed CDC because of from setbacks (about 1m). I spoke with council and they suggested we submit via DA as they would have no issues approving the designs and setbacks as they stand. Upon requesting to go the DA, my builder has now sent me a PCV for $12K that includes a Drop Edge Beam around the side and rear elevations. Hoping someone can explain to me how this can change between CDC and DA approval requirements. Or in fact why it changed, or do you think this is last minute oversight and they have forgotten to ad it to the plans earlier. And if so, why would this be a PCV? Photos are before and after side cut of plant. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Brickface Re: Drop Edged beam for Council but not CDC 2Mar 21, 2020 7:51 am They are not proper certified engineering drawings The engineers certification details should be on them eg here Checking Concrete Piles with BOSCH Laser + App Then its possible to work out an estimate for the extra concrete for the deep edge beam OT make sure you are looking at the soil geotech soil report and correct engineering certified drawings and details. The above are the Builders cross sectional drawings which can't be used for Slab/Footing engineering CDC Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drop Edged beam for Council but not CDC 3Mar 21, 2020 1:37 pm Thanks StructuralBIMGuy These are the drawings I signed off on my contract. If Im reading them correcty, there is no indication of drop Edge Beams. To be honest, I dont have an issue with Drop Edge Beams, far from it. I have a problem with the matter that these have been added as a PCV. They were not needed/mention for contract, CDC, but now raised for DA. To me it feels like a last dash for cash or a negligent miss on behalf of the builder? Thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Brickface Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12913 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27344 I would like to build our new house with the rear section approx 1 metre out of the ground, I don't particularly like to go bearers and joists so concrete slab all the way… 0 3845 |
