Browse Forums Building A New House 1 Mar 15, 2020 10:31 am Building a townhouse, with a single garage (3.5m x 6m) up against the boundary. However, the upper floor must be at least 1.8m from the boundary, resulting in the upper floor boundary wall spanning from one end of the garage to the other (6m). See attached pic. Does this large span incur significant additional engineering and cost (brick veneer)? The alternative is to not build over the garage at all, so the upper floor boundary wall is fully supported by the garage wall. Looking for advice on potential costs impacts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Engineering for build half-way over garage 2Mar 16, 2020 2:04 pm Hi timpm Welcome to the forum There should be a lintel over the garage opening It requires a stub column and Beam/Lintel to carry the 1st floor brickwork..Beam material cost Approx $500 + crane + Site weld etc Ask your builder for the engineering detail Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31747 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14609 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4506 |
