Browse Forums Building A New House 1 Mar 04, 2020 11:19 am Hi all, Just wondering what your thoughts are about building a timber frame house on a block that has previously had termites on it (eaten out some of our old shed frame and fence posts). We are doing a knock down rebuild and just aren't sure whether to go with steel because of these concerns. How effective are the current termite treatments to protect our future home? Which are the best treatments? If we went with timber frame is it worth upgrading to treated timber? Is this an effective deterrent? Or do we also need to get the house sprayed frequently (I'm not a fan of chemicals, but still less a fan of termites)? Are the bait systems any good? Or are these ongoing treatments so expensive over 10-15 years maybe we should just pay a little extra for steel? Thanks for your help. Re: Termites concerns when building with timber frame 2Mar 04, 2020 11:25 am Forgot to ask whether treated timber frames are good to have ON TOP of termimesh or is that going overboard? I was just really put off by a building salesperson who dismissed my concerns about the termites and interest in termimesh, saying that "almost everyone builds with timber, spray is enough, don't need termimesh." I guess that company doesn't like termimesh but my termite concern is valid and I would prefer not to have to spray regularly. Re: Termites concerns when building with timber frame 3Mar 04, 2020 2:33 pm Hi I think you should go for the steel one. Any ways only treatment for the termites is to use chemicals. I'm not sure how long it will stay dormant and when to do treatment again. If you want to control termites I have few tips 1.Choose a pest control company carefully [b]2.Read the pesticide product label[/b] [b][b]3.Be aware of the how soon you can return to the treated residence [/b][/b] Re: Termites concerns when building with timber frame 4Mar 04, 2020 8:29 pm Where are you located? I'm a builder and licensed pest controller. You just need to build smart with some easy termite control and you will have no problems. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Termites concerns when building with timber frame 5Mar 04, 2020 8:29 pm Where are you located? I'm a builder and licensed pest controller. You just need to build smart with some easy termite control and you will have no problems. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Termites concerns when building with timber frame 6Mar 04, 2020 8:29 pm Where are you located? I'm a builder and licensed pest controller. You just need to build smart with some easy termite control and you will have no problems. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Termites concerns when building with timber frame 7Mar 04, 2020 8:48 pm MClark Where are you located? I'm a builder and licensed pest controller. You just need to build smart with some easy termite control and you will have no problems. Hi, we are near Adelaide, SA. When you say "build smart" what do you mean please?? Thanks Re: Termites concerns when building with timber frame 8Mar 04, 2020 9:47 pm Underthesky MClark Where are you located? I'm a builder and licensed pest controller. You just need to build smart with some easy termite control and you will have no problems. Hi, we are near Adelaide, SA. When you say "build smart" what do you mean please?? Thanks Physical barriers put in place are the most affordable solutions to avoid termite damage. Having a subfloor with good access and the right protection put in place is easy to manage. A slab on ground with the slab edge exposed plus a kordon barrier around the perimeter is another standard way of construction that works quiet well. Once you start introducing paved areas around the home against the slab, raised garden beds, poor access into subfloors that is when you will start looking into treatments which can be costly and need to be undertaken as required by the product used. The build smart method will only need inspections to be undertaken regularly and that is it. Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Termites concerns when building with timber frame 9May 17, 2021 6:07 pm Physical barriers provide a long term solution compared to chemical barriers. However, the efficiency of your physical barrier is greatly dependent on the materials you use. We usually recommends stainless steel mesh and treated timbers to our customers. They are also cost friendly. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8052 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14652 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 |
