Approaching builders - advice please
We are at a stage with our prospective build, that we have our plans finalised and have our engineering drawings.
We had previously had early discussions with 3 builders regarding the project. We would now like to formally request that they
provide a quote based on our finalised drawings.
Is there any specific format or questions that should be raised at this point? - sorry if this sounds like a dumb question.
Or do we just email the plans, advise the sort of spec we are looking for and wait for them to come back. Then once we have
decided on the builder get into the details?
Its all new to us, so hoping for some good advice, thanks in advance.
If you're in Vic I might be able to join in
Good luck
However, now that you have a design, get a contour/feature survey and a soil analysis so all three builders can quote more properly. After the contour, why not get a quote for the earthworks also to judge if the builder intends to rip you off; you are not to get your own contractor on board, so this is just an integrity check!
The money you spend with your own design/contour/soil analysis is worthwhile; I found one builder dropped his price by $10,000 once he was told he might be out of the race!
The money you spend with your own design/contour/soil analysis is worthwhile; I found one builder dropped his price by $10,000 once he was told he might be out of the race![/quote:yp1q45dv]
Hey domwild,
With regards to slab thickness this is not a specification the builder gets to choose. This is specified by the engineer depending on the soil classification and the type of slab construction they are designing for (raft/pod). So a 85mm slab thickness for a engineered pod system for soil classifications A, S & M are perfectly fine providing they are constructed as per engineering.
I do agree with the rest of your advice though, as every builder has a totally different way of pricing & "standard" inclusions. It pays to read over the tender in great detail!
Cheers,
do you guys mean 85mm? last time I checked the standard it was 85mm.
You are correct! Apologies for the typo, I have updated my original comment.
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
8/06/2023
A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we…
7/08/2023
5
I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I…
